ducati748 Occasional Visitor
Posted: Sat May 13, 2006 5:55 pm Post subject: v605 and v632 maps |
can anybody tell me if the v605 or v632 uk maps will run on 5.1 or do i need to upgrade to 5.2
thanks in advance. |
adamf Lifetime Member
Joined: Jul 31, 2004 Posts: 410 Location: wolverhampton
Posted: Sun May 14, 2006 12:51 am Post subject: |
yes you might need to activate them first i did  |
Posted: Mon May 15, 2006 4:06 pm Post subject: |
adamf wrote: | yes you might need to activate them first i did  | thanks for the reply, the reason i asked is, i am running 5.1 and my old map was v563 so i replaced it with the v605 and returned my favorate places to the map, but when i turned it on although everything worked ok for some reason it has erased about half my favorate places, ive repeated the instalation a number of times and it still erases them, the folder is 19mb in size when i add it to the map and it then reduces it to 9mb, got any idea,s??
peterc10 Frequent Visitor
Posted: Mon May 15, 2006 5:50 pm Post subject: |
Long shot .... but are you running out of space on the card? _________________ Peter
HTC Sensation
Copilot for USA
Posted: Mon May 15, 2006 5:57 pm Post subject: |
peterc10 wrote: | Long shot .... but are you running out of space on the card? | i have a 256mb card and it is using just over 170mb the new map is only slighty larger than the old one so i would,nt of thought it would affect it. i never had problems with the old map only since i have loaded v605 have the favorates erased. |
Posted: Tue May 16, 2006 1:07 am Post subject: |
all favs etc are stored in the map so if you change map etc you have to start again search the forum for which folder they are stored in .
this subject of backing up favs has been covered sevrel times  |
wazzzzupmate Regular Visitor
Posted: Tue May 16, 2006 9:52 am Post subject: |
The favourites are stored in the cfg file. Not got my pda with me today but if you are using great britain map then the file you need to backup/copy is called something like greatbritainmap.cfg. Hope this helps, I can check my pda later if needed. |
