Pocket GPS World :: View topic - X51v MemoryMap Bluetooth issues?
psyklik
PostPosted: Sun May 14, 2006 11:41 pm    Post subject: X51v MemoryMap Bluetooth issues? Reply with quote
I recently purchased Memory-Map Navigator as replacement Maptech's Pocket Navigator, tired of waiting for their WM5 version and am having difficulty getting MemoryMap running on the Axim X51v.
My system uses a NMEA "$GPRMC" to my laptop via serial cable (Com3), there running Nobeltec VNS. The signal is then transmitted via a VNS repeater port to a D-Link BT transmitter (Com4) for reception on my X51v for Memory-Map Navigator. The X51v Bluetooth utility shows COM7 & COM8 as the only available Bluetooth COM ports. Memory-Map Pkt-Navigator lists COM5: BT UART on COM5.
- The X51v Bluetooth is set to COM7 is Incoming Port.
- GPS Program port is set to COM7
- GPS Access: ‘Manage GPS automatically’ I’ve tried checked/unchecked.
- MM Navigator is set to COM7 & checked for NMEA
- What about the GPS Hardware port?
I assume it should be set to ‘none’ yet have tried COM8, while setting BT to COM8 outgoing port?
The PDA shows a successful BT connection, yet the BT symbols darken only when I have an outgoing port (using COM8). I've tried all the combinations I could think of to no avail.
This system has worked fine the past couple of years with MT's Pocket Navigator on my previous Dell X30i.
So far no reception, GPS: Communication time out
Any suggestions?
psyklik
23.092 (10 Sep 25)
