timanfiya Regular Visitor
Posted: Sat Feb 11, 2006 5:26 pm Post subject: |
Glad you got it sorted Cobbie. Enjoy. Just think of all those macdonalds you will know are lurking around the corner. My son wants me to set up an alert for them - not too sure about that one, it could be expensive.
Still want to sort out this bug about rearranging the poi's in favs so they list in order of distance and not alphabet. Has anyone got any thoughts on this?? _________________ Goodmans GNAV10
WinCE 4.20(0)
OEM: Centrality Communication Inc
Destinator OP v 5.1.174 |
hoppo Occasional Visitor
Posted: Sun Feb 12, 2006 7:09 pm Post subject: |
Hi all,
I have at last managed to get the cameras working on my PB GPS 400, thanks to all of you and and the work you have put in. Even got the different voices working! The magic comment was 'click on the eye' I have only just found out what you meant after three weeks of looking. Having a really thick spell.
Thanks again all, hope I can provide something in the future.
Hoppo |
Indigo Occasional Visitor
Posted: Tue Mar 07, 2006 1:07 am Post subject: |
Excellent post just what i was looking for.
But i have 2 problems.
1.when i got the database the files you mentioned are not in .csv format but excel? however when i do the virus scan it says there .csv files but when i go to view show detail its says there microsoft exel documents.
2.there is no import under my favorites.
This unit is brand new and using Destinator OP ver 5.1.174
Not sure if that has anything to do with it.
Any help would be much apriciated as points on my licence are not an option |
Posted: Tue Mar 07, 2006 11:11 pm Post subject: |
never mind i found it |
gklrgibson Occasional Visitor
Posted: Fri Apr 21, 2006 9:34 pm Post subject: Destinator console |
I've followed your post but when I try to import favourites I get an error
"no data, count of badrecords = 972"
Have I downloaded the correct files? |
xbox456 Occasional Visitor
Posted: Sun May 14, 2006 3:38 pm Post subject: |
Hi, reading you post tells me your an expert on the gnav10, I have been given a unit but cannot workout how to update , I have active sync 3.8 and detinator op, but am convinced its out of date.
Can you give me some easy to follow advice
regards,
Terry |
Posted: Sun May 14, 2006 3:57 pm Post subject: |
Hi sory to be a pain but where di I find this:-
Import these files one by one using the Destinator Console Favorites import. |
tools Occasional Visitor
Posted: Thu Jul 27, 2006 3:06 am Post subject: |
can you please tell me which cam database to down load as i dont know im really not sure what to do please help thank you |
Greenglide Lifetime Member
Joined: Apr 04, 2006 Posts: 295 Location: South East Northumberland, UK
Posted: Thu Jul 27, 2006 1:15 pm Post subject: |
I have Destinator V6 and use the files for Destinator V3 without a problem.
If you want the speed category ones (ie lots) then these do not appear to be available for Destinator - either use the "Other" download and swap the columns into the correct order with Excel (this is why people who have tried this preiously havent got it to work, the data sequence on each line is different) or use the TomTom version and convert them using POI edit. |
flyingscotsman Occasional Visitor
Posted: Wed Aug 09, 2006 2:57 pm Post subject: |
Could someone tell me which is the best Database to download for the speed cameras, I have aGnav10 and Im very new to sat nav equipment.
i would be grateful for any advice . |
Posted: Thu Aug 10, 2006 10:41 am Post subject: |
As long as you dont want they individual speed zoned version but simply GATSO, TEMP, MOBILE, SPECS and REDLIGHT use the Destinator V3.
If you want the fully zoned version use the "Other" version and rearrange the columns in the CSV file with Excel (or similar) to be in the same sequence as the Destinator V3 file. |
Posted: Thu Aug 10, 2006 1:42 pm Post subject: |
For the non individual zoned version would that be the (Uk-single file with all cameras Database) in Destinator 3 database .
Thanks for your help Greenglide. |
Posted: Thu Aug 10, 2006 4:52 pm Post subject: |
You have a choice - the single file which doesnt distinguish between camera types and the five or six file version by type.
I use the cameras by type (can't remember the exact title in the download list and my subscription has expired for the moment) as a Gatso is more important than a Mobile! |
Posted: Thu Aug 10, 2006 7:18 pm Post subject: |
Ive mamged to get the camera database on but im having trouble finding the following areas
Resident Flash/DestinatorApps/Destinator/Common/Interface/Voice/All
ResidentFlash/DestinatorApps/Destinator/Common/Favorites
to lace the icons and voices into .
Help |
Posted: Fri Aug 11, 2006 10:18 am Post subject: |
Depending on the version of Destinator and the platform - PDA, dedicated etc.
Starting at the top level of the device go to "Mobile device", "Resident Flash" flash memory card or whatever the device where the application is installed and find "DestinatorApps".
From there it is merely a question of wandering around the device until you find the required folders.
The voice directory will have lots of files with names like roundabout, leftturn etc with extensions *.spx, *.ogg or *.wav (depending on version). The Favourites folder will have *bmp .dat etc files and in my case has files names camera.bmp present (I dont use these). |
