Omzy Occasional Visitor
Posted: Fri May 12, 2006 9:27 pm Post subject: GPSViewer and SiFRDemo |
What does the 'powersave' and 'waas egnos' checkboxes do in GPSViewer?
Also I'm trying to use SiFRDemo, I've connected it to COM6 and baudrate 38400 but most of the options in the menu's are greyed out. |
lbendlin Pocket GPS Staff
Posted: Sat May 13, 2006 8:40 pm Post subject: |
When using SiRFDemo you need to switch the device to SiRF mode to see the menu options. Don't forget to switch back to NMEA when you are done. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
xda Lifetime Member
Posted: Sat May 13, 2006 8:54 pm Post subject: |
Lutz, is there a version of SIRFdemo that works on a PC using Bluetooth. the latest version insists on installing USB drivers and only shows Com 1 & 2 as available, and my Bluetooth unit needs Com 7. GPSInfo shows all com ports 1-12. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Sun May 14, 2006 12:22 am Post subject: |
how do I switch to sirf mode? |
Posted: Sun May 14, 2006 2:11 am Post subject: |
xda wrote: | Lutz, is there a version of SIRFdemo that works on a PC using Bluetooth. the latest version insists on installing USB drivers and only shows Com 1 & 2 as available, and my Bluetooth unit needs Com 7. GPSInfo shows all com ports 1-12. |
send me an email and I can send you my version.
Protocols are switched through the comms menu _________________ Lutz
xda Lifetime Member
Posted: Sun May 14, 2006 4:32 am Post subject: |
Email on it's way many thanks Lutz. _________________ Graham.
Posted: Sun May 14, 2006 3:44 pm Post subject: |
lbendlin wrote: | xda wrote: | Lutz, is there a version of SIRFdemo that works on a PC using Bluetooth. the latest version insists on installing USB drivers and only shows Com 1 & 2 as available, and my Bluetooth unit needs Com 7. GPSInfo shows all com ports 1-12. |
Protocols are switched through the comms menu |
As stated, all the menu options are greyed out. And where is the comms menu? I have SiRFDemo 3.81 |
Posted: Tue May 16, 2006 10:18 pm Post subject: |
BUMP
Anyone know? |
Posted: Tue May 16, 2006 10:23 pm Post subject: |
Setup...Data Source - your port at 38400 , ok
Action...Open Data Source
Action...Switch to SiRF protocol _________________ Lutz
