Pocket GPS World :: View topic - Garmin i3
Garmin i3
gummydave
PostPosted: Sat May 13, 2006 2:27 pm    Post subject: Garmin i3 Reply with quote
How can I clear the recently found lists on my Garmin i3.
cheers
timber
PostPosted: Sat May 13, 2006 3:34 pm    Post subject: Re: Garmin i3 Reply with quote
cheers
If your sure you want to clear them all (they overwrite and show from memory the last 20 locations)
The method i use with unit switched off Exclamation is to press left button, thumbwheel and hold them then press right hand button (all three together) from the menu Do you really want to erase all user Data select yes
Check that all your settings are as you want as these are set to the default. Thumbs Up
ben_e71
PostPosted: Sat May 13, 2006 6:15 pm    Post subject: Re: Garmin i3 Reply with quote
cheers
Why have you got somewhere embarrassing in there? :D
22.094 (25 Sep 24)
