Pocket GPS World :: View topic - Overheating battery on iPaq rx3715
acmp
PostPosted: Wed May 10, 2006 10:41 pm    Post subject: Overheating battery on iPaq rx3715 Reply with quote
Does anyone else get this, when the unit is in use on warm days it occasionally says 'charging disabled, battery over heating' or something.
It seems to be when the sun is on the unit and it does get quite warm. And it only happens then so I don't think it's a real problem with the unit.
I have a goose neck mount on the screen and everything is pretty dark colours.
I was thinking about making a 'heat shield' from white card to slip on the back of the mount but I'm concerned about reflection.
Any thoughts?
xda
PostPosted: Thu May 11, 2006 5:13 am    Post subject: Reply with quote
You could try using a vent mount. Then on warm days you can use the air from the vent to keep it cool.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
lbendlin
PostPosted: Thu May 11, 2006 5:23 am    Post subject: Reply with quote
Seconded. Over here this is sometimes the only method to get the unit back to life after it has (inadvertedly) been baked in the sun for an hour 8O
Lutz
TomTom/TeleAtlas NAVTEQ
acmp
PostPosted: Sat May 13, 2006 7:14 pm    Post subject: Reply with quote
Dang, Well at least I know it's not just me.
I like the screen mount as it keeps the unit visible so I don't need to look too far from the road to see it (it's just below the bottom of the screen now that I have it mounted in landscape)
I tried a piece of white card but that didn't work at all. I have a look around for some good vent mounts and try one.
xda
PostPosted: Sat May 13, 2006 8:25 pm    Post subject: Reply with quote
Depending on what type of car you have some of the Brodit Pro clips hook over the centre vents, locating on the top and bottom of the vent surround. This leaves the vent in full use, thats how one of mine fits on a Rover 600. About £15.00 for a pro clip and is much more rigid than using the vent.
Graham.
Nokia 925 Windows 8
acmp
PostPosted: Mon May 15, 2006 9:34 pm    Post subject: Reply with quote
I have a Daewoo Lanos Embarassed
Mikeact
PostPosted: Mon May 15, 2006 11:32 pm    Post subject: Reply with quote
A what ?
22.094 (25 Sep 24)
