Pocket GPS World :: View topic - Wiring in Tom Tom One
Leblanc
PostPosted: Mon May 08, 2006 8:31 pm    Post subject: Wiring in Tom Tom One Reply with quote
My cigar lighter is behind the handbrake, so a long way from the dash or windscreen.
Can I wire the TT1 into say the glove box light or some other near by connection?
steveJ
PostPosted: Mon May 08, 2006 8:43 pm    Post subject: Reply with quote
Hi Leblanc,
You can wire your TomTom into a 12Volt supply, but you MUST use a cigar lighter socket, and do not cut the cigar plug off your TomTom lead.
The reason for this is that the cigar lighter adaptor regulates the 12Volt supply down to the 5 Volt 2Amp feed required using circuitry inside it.
If you try and wire your TomTom directly to the 12 Volt supply you WILL fry it!! Sad
Steve
peterc10
PostPosted: Mon May 08, 2006 10:55 pm    Post subject: Reply with quote
This can be done using an in line cigarette lighter hidden behind the dash. Normally you can pick up the feed from the audio - with choice of switched (ignition) or permanent live. I would not use a lighting circuit as the design load will be too low and the fuse may blow.
Peter
HTC Sensation
Copilot for USA
999tommo
PostPosted: Tue May 09, 2006 10:42 am    Post subject: Reply with quote
It may be better to use a switched (ignition) supply as you don't really want a hidden lighter socket being permanently live, in case it causes a fire.
Tommo...
Regularly absent, but still here in spirit !
Leblanc
PostPosted: Tue May 09, 2006 9:25 pm    Post subject: Reply with quote
Thanks,
I suspected something like this, which is why I posted.
Leblanc
PostPosted: Thu May 11, 2006 10:56 am    Post subject: Reply with quote
I think I will just keep recharging the Tom Tom One so there will be no trailing wires, and the unit will be easy to remove when I leave the car.
