Pocket GPS World :: View topic - Voice warnings for speed camera
RoyMathews
PostPosted: Tue May 09, 2006 8:57 pm    Post subject: Voice warnings for speed camera Reply with quote
I recently installed the speed camera database and the voice warnings, without any major problems. All is working well. My problem is I seem to have used all available warnings noises. So now when I'm approaching a low bridge I get the voice warning for one of the cameras. Is there a solution to this? Can you install additional sounds?
MR_TiGGer
PostPosted: Tue May 09, 2006 9:04 pm    Post subject: Reply with quote
If it helps I found that all the different types are on the same tone, except Red Light cams cos I wouldn't consider jumping them.
Ultimately one tone for the cams and you're gonna look anyway so what difference does it make? Also common sense will probably tell you what speed you should be at.
Solves your problem in a single hit 8O
Just my take on it :D
PostPosted: Tue May 09, 2006 9:25 pm    Post subject: Reply with quote
You only get 15 warnings within the data.chk file but you can use POIExtend to increase this to 30 specific warnings, have a look at www.tomtomsatnav.info its a bit of messing around but allows you to "cook" your own data.chk file that you can then load up to the device, worth having a look at if you have hit the 15 limit and want more - back the device up first though, you could mess up the device if you get it wrong - Mike
22.064 (26 Jun 24)
