Pocket GPS World :: View topic - O2 XDA II / 2 which GPS Hardware ??
NickR
PostPosted: Wed Nov 19, 2003 2:38 pm    Post subject: O2 XDA II / 2 which GPS Hardware ?? Reply with quote
I am thinking of buying a O2 XDA II PDA, I notice there is a problem with Bluetooth gps units, can anyone tell me if there is a problem with cable gps units?? If not can you recomend which gps unit to buy?
Nick
PostPosted: Wed Nov 19, 2003 4:50 pm    Post subject: Reply with quote
cable (serial) GPS should be just fine. When the CF Backpack comes out you will also be able to use CF GPS receivers.
As for the BlueTooth - I am pretty sure O2 and the other providers will force the manufacturer of the XDA2/MDA2 or whatever else it is called to adjust the ROM and add the Serial Port Profile to the Bluetooth stack. Patience...
NickR
PostPosted: Wed Nov 19, 2003 5:20 pm    Post subject: Reply with quote
thanks for your reply, do you know if the serial connector is the same on the XDA 1as the XDA II ??
Nick
PostPosted: Wed Nov 19, 2003 5:43 pm    Post subject: Reply with quote
yes, it's the same
pdupreez
PostPosted: Fri Jan 02, 2004 11:54 pm    Post subject: Reply with quote
I am using a Fortuna Clip-On Bluetooth receiver with my XDA II, with TT 2 software with the Ver 2.09 update. It works perfectly without problems.
If you do not use the TT software use the patch from TOWA available at http://bluetooth.i-networx.de, it works fine!
Regards Laughing
22.063 (19 Jun 24)
