Pocket GPS World :: View topic - check point
check point
roughsex
PostPosted: Sun Apr 30, 2006 8:00 pm    Post subject: check point Reply with quote
As I usually forget about my pda over the winter months
The battery goes flat and i have to go through the boring setup procedure
So I have just set it up so that I don’t have to
My question is I put checkpoint on to the sd card
But when I click on the icon it comes up with not a valid program
Or something like that
Does this program have to be installed from a pc?
roughsex
PostPosted: Sun Apr 30, 2006 11:11 pm    Post subject: Reply with quote
When installed from pc it puts files in a checkpoint folder
In programs files 7 files in all
If I copy these files to the sd card
So if the battery goes flat I put these files back were they were
Will checkpoint work properly
Or do I have to use the setup program using a pc
These may seem to be a strange question
But I do not have a pc
And I am quite forgetful in not charging my pda
So then I have to bug my mate in setting it up again
Using his pc
Robin2
PostPosted: Mon May 01, 2006 1:03 am    Post subject: Reply with quote
Why don't you buy Sprite backup.Then you can back up the entire contents of your PDA to your storage card, and if you ever lose it because your battery runs flat, you can immediately get back to where you were
Robin
Satmap Active 10
roughsex
PostPosted: Tue May 02, 2006 2:53 pm    Post subject: Reply with quote
Thanks robin
What a brilliant piece of software
I wish I had known about this earlier
Just one more question on check point
When you go into overlay settings
It says no image next to the speed cameras
How do I get this to show the pic of the camera
roughsex
PostPosted: Tue May 02, 2006 8:37 pm    Post subject: Reply with quote
Also in overlay setting it says not synchronized whys this
I am using the single file cameras
But when I downloaded these through checkpoint
I’m sure it did not say this
Robin2
PostPosted: Tue May 02, 2006 9:47 pm    Post subject: Reply with quote
When you copy the OV2 file into your map folder, also copy across the bmp file and the camera icon will appear on your map as you approach it.
Not synchronised means that you haven't used CheckPOInt's automatic update facility. Now that the Pocket GPS files are subscription based, this doesn't work anyway.
If you expand the list of overlay files, highlight the safety camera file you put in your map folder, tap properties and you can then set up what warnings/messages you want to be played. I have the separate speed zoned files, so I have set up a speed warning which only sounds if I am over the prescribed speed
Robin
Satmap Active 10
two_bus
PostPosted: Fri May 05, 2006 11:00 am    Post subject: Reply with quote
i've used checkpoint with tomtom 3 but now i've downloaded checkpoint v5 for ttn 5.21, checkpoint won't find the map i'm using and so won't work.
all i get on the overlay settings is ..... not sync'd....... and i can't expand anything.
i'm using a great britain map as installed by ttn in the default folder name.
any ideas would be much appreciated
Robin2
PostPosted: Fri May 05, 2006 12:09 pm    Post subject: Reply with quote
Silly question, but have you installed the OV2 and bmp files in the same folder as your GB maps. If so, expanding the overlay settings should show your safety camera files, and highlighting each and clicking proerties enables you to set up the warnings
Robin
Satmap Active 10
two_bus
PostPosted: Fri May 05, 2006 1:20 pm    Post subject: Reply with quote
Laughing Out Loud Rolling Eyes yes robin, it all works fine for ttn, all the poi's work great. bmp's as well Laughing Out Loud.
just checkpoint won't see the any of it. i wondered if its lookin for a different map name or something??
i seem to remember i had some trouble setting up checkpoint when i had it on ttn3 too. maybe i should re install the map?
if i fix it before anyone else has a solution i'll post and let you know how i did it.
just a thought... could it be cos i have another card with belgium map on from when i went on holiday? all i did was install each map on a different card and then swap cards when i needed to
22.063 (19 Jun 24)
