Pocket GPS World :: View topic - 910 Screen Mount - Anyone Dismantled It Yet ?
SpeedCam
PostPosted: Mon May 01, 2006 7:44 pm    Post subject: 910 Screen Mount - Anyone Dismantled It Yet ? Reply with quote
Has anyone managed to dismantle it yet, reason for asking is that I'd like to mount it on my existing Brodit mount.
As there are no replacements available, I'm a little reluctant to mess to much at the moment.
PostPosted: Tue May 02, 2006 4:36 pm    Post subject: Reply with quote
yes, you need a T8 Torx. Three screws.
The problem is that the holder is a metal T-piece. I can't see how you can easily affix that to a Brodit mount. You also need to be concerned about the mounting depth - vibrations will amplify because of the device weight.
bryson
PostPosted: Wed May 03, 2006 11:37 am    Post subject: Reply with quote
Ill let you know when a new Brodit mount will be available for the 510/710/910 series from Brodit.
As a reseller of Brodit gear I am getting quite a few requests already, and having looked into the existing mounts fitting the new *10 series, im afraid it is a totally different system, PM me if you need any more advice,
Thanks again,
Bryson
CeeJay
PostPosted: Thu May 04, 2006 12:33 am    Post subject: Reply with quote
Hi bryson.
Glad your on the case.
I absolutely hate the new mount with a passion.
Need one urgently.
CeeJay
bryson
PostPosted: Thu May 04, 2006 12:19 pm    Post subject: Reply with quote
Brodit have a x10 device they are working on, as suspected it is a totally new mounting system, and they are not 100% sure they will be able to release a new holder for th x10 series, however, we shall find out more soon, but they did say at least 4 weeks, which im sure they would not have said if they were not confident of succsefully making a new holder! Fingers crossed!
Ill keep you all posted with any more news,
Thanks all,
Bryson
mikeiow
PostPosted: Tue Jan 02, 2007 9:42 am    Post subject: Reply with quote
Not sure whether you think there is now a Brodit mount, but Brodit have just told me they have no plans to make one for the 710 & 910 models !!!
ho hum
cheers
Mike
Pedro2NR
PostPosted: Wed Jan 03, 2007 5:59 am    Post subject: Reply with quote
http://www.arat.de/nemet/cnz/bildsch/bsch_neu.asp
Scroll down and you will see the x10 mount.
PostPosted: Fri Jan 05, 2007 10:28 pm    Post subject: Reply with quote
Cute - this one is actually using the original mount, or at least parts of it. Pretty much the same as a disk glued to the dashboard...
Exhale
PostPosted: Mon Jan 15, 2007 8:38 pm    Post subject: Reply with quote
It's very easy to disassemble to suction assembly - for example if you want to screw it to something else (like I've done here) - just pop a watchmaker's flat blade screwdriver into the join between the base of the suction cone (the large end) and the removable top (the narrow, slightly lighter end).
With the ring popped off, you turn the base as if you were undoing the mount from a screen and push the suction cup into the base to expose the metal retaining bar which runs across the inside of the base.
You then need to use thin pliers to pull the bar out of the hole a bit - once it's moved a small amount, you can get a lever onto the other side of the bar and push it out (carefully! As soon as the bar's out, the whole suction cup assembly falls apart).
Reassembly is a little fiddly but definitely possible.
/al
22.064 (26 Jun 24)
