aliaird Occasional Visitor
Posted: Tue May 02, 2006 4:46 pm Post subject: TTN5 simply as Speed Camera Warner |
IS it possible to set up TTN5 on my PDA simply as a warning device for speed cameras? It works fine when I have gone to the effort of putting in a route, the machine beeps at me as I approach a Speed Camera.
But if I know where I am going to I can't seem to just have it on and warning me as I approach speed cameras, like I imagine bespoke GPS Speed Camera systems do.
I've tried it with POIs showing and hidden and it doesn't seem to make any difference, it won't warn me unless i have set an address and it's worked out a route, which is sometimes a bit of overkill when I know where I am going and how to get there but might not know all the speed camera points.
Any ideas anyone?
Thanks in advance.
Al |
The_Pilgrim Regular Visitor
Posted: Tue May 02, 2006 5:54 pm Post subject: |
Hi Al
When you set up POI detection there is a check box called "warn only if on route" (or something like that) if you uncheck this box you will get the warnings whether a route is planned or not.
Regards
The pilgrim _________________ We are the Pilgrims: master, we shall go always a little further. |
Posted: Tue May 02, 2006 6:08 pm Post subject: |
Thanks Pilgrim
I'll try that.
Does this mean though that when I am on a route, it will ping whenever I go near a camera even if not on route? Does this make much difference in practice or not? :o
It would be a shame to have to go through each Camera POI and change settings depending on whether I was planning on putting in a route or not.
Any more info gratefully received.
regards
Al |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Tue May 02, 2006 6:28 pm Post subject: |
Quote: | It would be a shame to have to go through each Camera POI and change settings depending on whether I was planning on putting in a route or not.
| It's best to leave it as 'Warn when near' all the time, otherwise you won't get a warning of cameras on bridges that are not on route.. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
