Ash10 Pocket GPS Verifier
Posted: Sat Apr 29, 2006 10:58 pm Post subject: [i3] Curly / coiled power leads? |
Can anyone point me in the direction of a curly fag-lighter to mini-USB lead? The USB end doesn't need to be right-angled particularly.
I know that quite a few modern mobile phones use mini-USB for charging - but I'm not sure of specific models.
I did have a quick look on eBay, but everyone seems to use generic pictures - so you can't see exactly what you're getting. |
matb Frequent Visitor
Jamas Regular Visitor
Joined: Mar 02, 2006 Posts: 76 Location: Toulouse-France
Posted: Sun Apr 30, 2006 9:18 am Post subject: Re: [i3] Curly / coiled power leads? |
Ash10 wrote: | Can anyone point me in the direction of a curly fag-lighter to mini-USB lead? The USB end doesn't need to be right-angled particularly. |
You could also use an ipod car charger with a standard "USB to mini USB" cable.
Should deliver a voltage close to 5V (is it too much for the i3 ?) but worth to check !
Jamas _________________ SP i3 S/W 2.9-> 2.7 City Navigator V8 NT+ |
DracUK Regular Visitor
Posted: Sun Apr 30, 2006 7:21 pm Post subject: |
If its the same as a c320 you can use an Original Motorola v3 charging cable.You can even buy the right angled adapter if required.
DracUK |
Posted: Sun Apr 30, 2006 8:22 pm Post subject: |
Funny you should say that, I've just ordered a v3 charging lead - I'll post an update once it arrives...  |
greeny67 Occasional Visitor
Posted: Mon May 01, 2006 9:46 pm Post subject: |
Im using a motorola V3 12 volt ciggy lead bought from ebay for less than three pounds shipped!! Works perfectly with my i3 and has a right angle connector and a coiled lead. |
bazelk Regular Visitor
Posted: Mon May 01, 2006 11:41 pm Post subject: |
greeny67 wrote: | Hi
That's what I have been looking for i,e the right angled version, don't suppose you would put the seller info here for all would you.
Regards |
Posted: Tue May 02, 2006 10:35 am Post subject: |
Many thanks for that greeny67,
will go take a look and order one :D |
bigadz7 Occasional Visitor
Posted: Fri May 05, 2006 9:40 am Post subject: |
Thanks for the tip-off greeny67
I've been looking for a couple of these to use on the bike/ wifes car so I don't have to take my nice fitted lead out of the car.
At £5.50 for 2 (including postage), it's a steal.  |
typan Occasional Visitor
Posted: Fri May 05, 2006 10:02 am Post subject: |
Yep thanks for that, just what i've been looking for ! |
Anita Pocket GPS Moderator
Posted: Fri May 05, 2006 10:18 am Post subject: |
[quote="greeny67"]I can confirm that it has a right angle connector and the coiled lead you are looking for.
Thanks, greeny67. Mine arrived today - good service and excellent price. Has a straight connector, not right-angled, but still preferable to the long lead on the original.
Was hoping for an angled one, though Maybe I'll e-mail him and see if he can swap it. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Fri May 05, 2006 11:19 am Post subject: |
Just realised the curly lead doesn't have the little cylindrical unit which, I believe, reduces the power delivered to the i3 from 12v to 5v.
Is it possible this is done by a different means with this lead, or will it deliver the full 12v, and therefore be unsuitable for the i3? _________________ Anita
UK map 1130.12368
Posted: Fri May 05, 2006 12:19 pm Post subject: |
Anita wrote: | Just realised the curly lead doesn't have the little cylindrical unit which, I believe, reduces the power delivered to the i3 from 12v to 5v.
Is it possible this is done by a different means with this lead, or will it deliver the full 12v, and therefore be unsuitable for the i3? |
The cylinder is a ferrite choke, used to help suppress electrical noise - it has nothing to do with the voltage. The voltage regulator is contained within the (oversize) cigarette-lighter plug itself.
If your new lead has the same plug on it as your original lead (ie: mini-USB), then you will be fine ;) |
Posted: Fri May 05, 2006 12:34 pm Post subject: |
Thanks very much, Ash10. Sorry if it was a stupid question.
In case anyone else is thinking of ordering, I emailed the supplier, who says he has none with a right-angled connector and offered a refund. I declined - for £2.95 it's hardly worth it, and I'll use it until I can find what I want. I think he has constantly changing stock, so it's probably pot luck what you get. _________________ Anita
UK map 1130.12368
