LesP2008 Lifetime Member
Posted: Sun Apr 30, 2006 10:41 am Post subject: Flashing Icon for Cameras |
Can anyone help, i had this on the 700 but can't for the life of me remember how it was done. I would like it on the 910. The voices are good but i use the M25 - A3 to M40 and with all those cameras so close, the voice would drive me nuts. |
Posted: Mon May 01, 2006 12:47 pm Post subject: |
Can anyone help with this?.
Also, does anyone else find the icons for the cameras to be small on the 910. On the 700 they always were easily seen from the driving position which was made a lot easier by the flashing icon in the top left hand corner. |
CeeJay Frequent Visitor
![](modules/Forums/images/avatars/gallery/avatar_sp_018.jpg)
Joined: Jan 06, 2006 Posts: 360 Location: East Sussex
Posted: Mon May 01, 2006 1:18 pm Post subject: |
Hi there GO-GO-910.
You should get the flashing icons automatically, once you set your cameras up.
By the way, are your icons the right colour? cos mine ain't. No red in the flashing box, but that's covered in another post.
CeeJay. |
alix776 Pocket GPS Moderator
Posted: Mon May 01, 2006 1:20 pm Post subject: |
its a very similar menu structe to the 700 go in to change preferences then manage poi then warn when near poi
there is somehting else to do with the text to speech but ive not got a 910 so cant help with that bit _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Mon May 01, 2006 1:48 pm Post subject: |
Thanks to all for the input.
So Alix am i right in saying you have to edit each camera group to warn if on route?, but then i will have a sound which i dont want. |
Posted: Mon May 01, 2006 2:03 pm Post subject: |
Use the Text to speach, if you select "Type in your own warning" on the next page type a couple of spaces and press done, the warn only if POI is on route is up to the individual, and yes you do need to do this for each camera you have loaded (full speed zoned is 23) - it took me about 45 mins on Friday to configure including spoken text inputs per camera. - Mike |
Posted: Mon May 01, 2006 2:33 pm Post subject: |
Thanks to you all i think i now have it licked.
I sort of figured out the bit about doing every file but as you may realise i got myself a bit confused with the gongs, bells and whistles warnings.
Glad to say i used my own text. I think before i may have had the bells etc active but as i generally had the sound off then all i would have got was the flashing icon..... i think!!!!!. |
