Pocket GPS World :: View topic - TomTom One signal issue
jm6451
PostPosted: Sat Apr 29, 2006 10:06 am    Post subject: TomTom One signal issue Reply with quote
Sometimes it can take over 5 minutes to pickup the satellites, is this normal?
Eldar
PostPosted: Sat Apr 29, 2006 5:44 pm    Post subject: Reply with quote
sometimes it is normal
jm6451
PostPosted: Sun Apr 30, 2006 12:37 pm    Post subject: Reply with quote
Do you need to be stationary to pick up the signal because if I pull over it seems to then pickup the signal.
PostPosted: Sun Apr 30, 2006 10:23 pm    Post subject: Reply with quote
If you drive off immediately after switching on the ONE, it takes longer to get a Sat Fix, because the reference points are constantly moving.
If you switch it on as you walk to the car, by the time you've fitted it to the cradle and started the car, you will probably have the fix you need.
Eldar
PostPosted: Mon May 01, 2006 1:32 am    Post subject: Reply with quote
have a look at this: http://www.satnav-shop.com/index.php?ln=en&pg=6&sec=11
22.063 (19 Jun 24)
