Pocket GPS World :: View topic - i3 mounts
i3 mounts
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Ash10
PostPosted: Sun Apr 30, 2006 1:03 pm    Post subject: Reply with quote
A big thank you to Mr. Gonzales for his, er, special balls! Confused
Spot the mount:
I like! 8)
Dilcymro
PostPosted: Sun Apr 30, 2006 2:00 pm    Post subject: Reply with quote
Hi all,
Nice job Ash10, did notice though that the ball is quite flush with the dash
does this mean that the i3 is square on, or can you twist it towards you a bit. Also were do your cables come out or do you run on the batterries?.
I have a couple of spare switch covers! on my dash I could use but need to run a cable for the arial and power lead.
Looks pretty good though and neat.
Regards....Dilwyn
Ash10
PostPosted: Sun Apr 30, 2006 2:24 pm    Post subject: Reply with quote
There's about +/-30 degrees freedom of movement - any more and I accidently either change the clock or switch the hazards on! Laughing
But that's plenty of adjustment for me - as I look down to the i3 it's completely facing me Smile
The power cable just drops down to the fag-lighter below (which is why I'm tying to source a curly/coiled one). I don't want to conceal the cable as I regularly switch between two cars...
Dilcymro
PostPosted: Sun Apr 30, 2006 2:49 pm    Post subject: Reply with quote
Thanks for the quick reply Ash10, Looks like I didnt need to buy that console for the car then!!! what about your arial, do you use one or the inbuilt one?, sorry to be a pain but I know Matb will be nosing around aswell so he`ll have everything planned out for when his wife gets home.
Rgards....Dilwyn
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
Ash10
PostPosted: Sun Apr 30, 2006 3:11 pm    Post subject: Reply with quote
I'm using the built-in antenna, seem to still get 4 or 5 green bars on the signal strength indicator - that's with a standard non-athermic windscreen and no sunroof.
Dilcymro
PostPosted: Sun Apr 30, 2006 3:26 pm    Post subject: Reply with quote
Thanks Ash, appreciated Laughing
regards...... Bouncing Dilwyn
matb
PostPosted: Sun Apr 30, 2006 11:14 pm    Post subject: Reply with quote
Rgards....Dilwyn
dilwyn
i feel like i have known you for years Exclamation
and the i3 returns, oh yes and the wife also.
i have been trying to post the picture of my mounting of mr. g's ball but can't fathum it out, ash give us a clue Wink
matb
PostPosted: Mon May 01, 2006 8:18 pm    Post subject: Reply with quote
and here is my example
thanks again mr.g
(posting of picture with help of ash10) Thumbs Up
Dilcymro
PostPosted: Mon May 01, 2006 8:28 pm    Post subject: Reply with quote
Congrats Matb you managed the photo then.....by the way how did you get that 90% angle on the arial connector, it didnt come like that!!!
Nice job too.
egards....Dilwyn
Garmin Nuvi 2415
porky48
PostPosted: Tue May 02, 2006 9:40 am    Post subject: UK supplier Reply with quote
zogman wrote:
a company called ''ram mounts'' make a 9/16'' size ball mount which i believe is equivilent to 17mm..they've named it an 'a' size ball and is available in the states but not over here yet...
There is also a UK supplier click on this link http://www.ram-mount-uk.com/
bumpkin
PostPosted: Tue May 02, 2006 11:05 am    Post subject: Re: UK supplier Reply with quote
I think it's been pointed out before that 9/16 is around 14.3mm, too small for the i3.
Got my custom Ram to i3 adaptor from Mr G on Saturday morning. Whilst the Ram adaptor was expensive (compared to a theoretical solution from Ram if the correct size balls were available) it looks great and works even better. I'll post a picture soon.
Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10
galaxy111
PostPosted: Tue May 02, 2006 12:38 pm    Post subject: Reply with quote
Interesting. What's the second lead? Is that for an audio output socket that you've added?
PostPosted: Tue May 02, 2006 2:15 pm    Post subject: Reply with quote
external aerial, i believe
matb
PostPosted: Tue May 02, 2006 3:28 pm    Post subject: Reply with quote
MaFt there are no flys on you my friend.
its the lead for my roof mounted A47FH aerial, £9.99 from maplins. Wink
stroker
PostPosted: Wed May 03, 2006 3:40 pm    Post subject: Mr G ....PM Sent Reply with quote
Re: "I Need your balls"
Page 5 of 8
23.052 (14 May 25)
