Pocket GPS World :: View topic - GPSlim 236 USB cable and Firmware upgrade question.
Goto page Previous  1, 2, 3, 4, 5, 6  Next
AllyCat
PostPosted: Wed Apr 26, 2006 4:23 pm    Post subject: Reply with quote
Hi Peter,
Well it's certainly more recent than mine Sad
I think the latest firmware reports 3.1.1 in the first line (mine is 3.1.0) and v5 in the last line (mine is v4).
So you probably don't need a USB data cable, which seems to be 19.98 UKP including VAT and shipping from Clove Technolgy to Denmark.
Cheers, Alan.
Garmin GPS72H/76/60/45, Etrex H, Mapsource v6.5.
Acer N50,HP114,Loox N560,Dell x50,CF/SD cards to 4/32GB.
RoyalTek,Holux236,Navman B10 & Copilot(Globalsat) BT GPS,TomTom5/6.
Memory Map (v5.4.2 & v5.1.3 OS & Euro), GPS gate,OSGPSconverter.
Peter322
PostPosted: Wed Apr 26, 2006 4:33 pm    Post subject: Reply with quote
Good news - thank you soo much for your help.
I think I'll just PM Julie from Holux just in case to check, but it sounds right what you are saying.
Peter
spikey_w
PostPosted: Wed Apr 26, 2006 5:58 pm    Post subject: Reply with quote
Peter,
Yes you've got the latest version, think I must have been unlucky to get older stock than yours. That's what I see after the upgrade. I had 3.1.0 before.
Peter322
PostPosted: Wed Apr 26, 2006 6:25 pm    Post subject: Reply with quote
Super, I guess I was lucky then - thanks to everyone for your help.
cheers
Peter
ro-76
PostPosted: Thu Apr 27, 2006 11:52 pm    Post subject: Reply with quote
spikey_w wrote:
Peter,
I just got mine from Nav4all today, and cannot get a fix. I have the old firmware:
$PSRFTXTVersion GSW3.1.0-SDK_3.1.00.07-C24P1.00 *46
$PSRFTXTTOW: 0*09
$PSRFTXTWK: 1313*49
$PSRFTXTPOS: 6378137 0 0*06
$PSRFTXTCLK: 96250*09
$PSRFTXTCHNL: 12*5F
$PSRFTXTBaud rate: 4800 System clock: 1124.403MHz*5E
$PSRFTXTVersion 236V4 * *4A
This is my second 236. The first had a bluetooth problem, so I returned it to the ebay seller I bought it from, and now this one cannot get a fix. The first unit got a fix within seconds. It was a newer serial number 236-6110 XXX. I may end up returning the nav4all unit and getting a replacement rather than refund from teh ebay seller.
I am a little sucpicious that the nav4all units are refurbished, considering the vary variable firmware, and variable performance reported from other users. It would also explain the lack of retail packaging, mains charger and the low price.
Anyhow, I PM'ed Julie from Holux, so may try a firmware upgrade to try to fix it.
Ro
ro-76
PostPosted: Fri Apr 28, 2006 11:23 am    Post subject: Reply with quote
I finally got a fix this morning, so I'll be monitoring performance. I still have my doubts about the Nav4all units, as to whether they are B-grade stock.
Ro
JM-HoluxUK
PostPosted: Fri Apr 28, 2006 1:06 pm    Post subject: Reply with quote
Hi All,
I have checked with Holux in Tiawan and the stock that Nav4All is not refurb. They simply have got the old firmware onboard. If you are having problems please contact Nav4All who should be able to offer the firmware to you.
If you are still having trouble please feel free to drop me a line & I'll help as best I can.
Cheers,
Julie
dannyoneill
PostPosted: Tue May 02, 2006 8:36 pm    Post subject: Reply with quote
is it possible to get the internal version using bluetooth?
Ive performed cold starts with Sirfdemo, gpsviewe and others but they never show the version info :S
ro-76
PostPosted: Tue May 02, 2006 8:45 pm    Post subject: Reply with quote
Yes. You can use GPSinfo.
Ro
dannyoneill
PostPosted: Tue May 02, 2006 8:48 pm    Post subject: Reply with quote
Curse my symbian phone :P
Visit Wayfinder Life for all your Wayfinder Navigator needs
jnjc
PostPosted: Wed May 10, 2006 5:02 pm    Post subject: Reply with quote
How? I tried upgrading through Bluetooth using SirfDemo/SirfFlash without success and had to use the USB cable instead!
HellFire wrote:
I upgraded my 236 through Bluetooth along time ago without a USB cable so why do you need a cable
fpaliuc
PostPosted: Sat Jun 10, 2006 5:13 pm    Post subject: Reply with quote
I saw on a german site that the last firmware version for Holux 236 is 6.1. Is it true?
dannyoneill
PostPosted: Mon Jun 12, 2006 11:06 am    Post subject: Reply with quote
I believe thats the latest hardware firmware as opposed to the latest software firmware (which is still 3.1.1 last time I heared)
AdamPetherick
PostPosted: Wed Jun 21, 2006 5:45 pm    Post subject: Reply with quote
is it just for the updates you need a special cable as I've connected mine to my PC using a standard mini usb cable and it's always worked fine as a wired device
AllyCat
PostPosted: Thu Jun 22, 2006 3:16 am    Post subject: Reply with quote
Hi Adam,
That's very surprising as the Holux236 doesn't use a USB interface (protocol) on its connector. The "standard" cable is only for charging the battery. The only way I can see it working is if (one of the following):
- Your "standard" mini USB cable actually includes a USB-serial converter "dongle" (like the "special" Holux cable).
- It's actually communicatting with the PC via Bluetooth.
- It's not a Holux 236.
Or has anyone any other ideas?
Cheers, Alan.
Page 4 of 6
