Pocket GPS World :: View topic - TT 910 UK Stock Map Versions
Flashyphotos
PostPosted: Thu Apr 27, 2006 1:34 pm    Post subject: TT 910 UK Stock Map Versions Reply with quote
Well Here are the Map Versions and Dates stored on the UK Shipped 910s
Build Date on All Files 15th April 2006
ID=Western_and_Central_Europe.pna
1318044307
650
build=1052
id=38915
ID=North_America.pna
1509524673
650
build=1052
id=39759
ID=Canary_Islands.pna
514011862
650
build=1045
id=38915
ID=Guam.pna
470354182
650
build=1050
id=39759
SpeedCam
PostPosted: Thu Apr 27, 2006 2:21 pm    Post subject: Reply with quote
Let us into a secret as to where you purchased your 910?
Flashyphotos
PostPosted: Thu Apr 27, 2006 2:32 pm    Post subject: Reply with quote
PCWorld Mansfield
Had a couple at lunch, followed by Derby and Nottingham, all now sold out, not sure who will be next on list, just keep checking the Collect at store option,
According to the insotr network all stores will have a limited supply of 910s my the weekend,
As Mansfield & Derby are supplied by Newark Central Distribution they got first dibs
Flashyphotos
PostPosted: Thu Apr 27, 2006 2:35 pm    Post subject: Reply with quote
Would not get a lock at first,
Quick Check found that the US Map was selected as standard!, soon as UK Map selected got a lock in 10 secs
So if anyone in the UK is getting on and cant get a lock, make sure you select the UK & Europe map from Switch Maps menu!
LesP2008
PostPosted: Sat Apr 29, 2006 6:14 pm    Post subject: Reply with quote
Richard, how do you see what map builds you have?. I have been flitting around the GO but can't find the obvious path. I miss the version number on the 700!!.
PostPosted: Sat Apr 29, 2006 6:58 pm    Post subject: Reply with quote
Use Windows Explorer to open the device and go to each map folder, within the map folder will be a file with the extension of .pna open this in note pad and it will display the same data as depicted above in the OP - Mike
LesP2008
PostPosted: Sat Apr 29, 2006 8:01 pm    Post subject: Reply with quote
Thanks Mike.
22.064 (26 Jun 24)
