boydonegood Occasional Visitor
Posted: Mon Apr 03, 2006 10:43 pm Post subject: |
Yeah read the MCX bit on the back of the Garmin aerial tonight in Lakeside.
The aerial i can get ya is a Bus GPS aerial,,,Looks n does the same as the aftermarket Garmin one. You need a SMA( i think..dont shoot me if wrong) adapter.Maplins dont go small enougth so they gotta come from RS at Bow.Near Blackwall tunnel....Only a cheap brass convertor from large(aerial socket) to small Garmin socket....Only sensible if your in a hurry or desperate..
If ya desperate ,desperate..like your going away,,,you can have mine n i'll wait for them to come in...Its been taken outta box n used for about 10 mins,,is not installed in car or nothing..So still brand new... |
iandee Occasional Visitor
Joined: Jan 22, 2006 Posts: 57 Location: Thundersley, Essex UK
Posted: Mon Apr 03, 2006 11:44 pm Post subject: |
No hurry Tel, thanks for info and reply tho
regards _________________ Ian Dee,
tommtom iphone6
bad elf TomTom25 |
Posted: Sun Apr 09, 2006 1:13 pm Post subject: |
:D Pleased to advise that I now have the Maplin external antenna from Maplins (Southend after all that). I agree with all, that it is excellent and the cost £9.99........... well :D amazing.
I am not putting it on the roof of my Scenic. I have stuck the Garmin dashboard disk on to the dashboard top and using the sucker holder am finding it ideal. The antenna I have positioned with blue tack (at the moment anyway) on the dotted part of the windscreen near the rear view mirror and hiding the wire behind the lining, with it going into and then out of the glove box, up and then on to the garmin. I can then easily disconnect and push the wires back into the glove box with the adapter from the cig lighter. I then remove the garmin from the dash when leaving the car.
The reception is very good and pick up rapid.
Many thanks to all you guys for this information about Maplins. Its saved at least £60 from the 'official' Garmin antenna and another major victory/ advocate for this forum
tommtom iphone6
bad elf TomTom25 |
matb Frequent Visitor
Posted: Wed Apr 19, 2006 8:14 pm Post subject: |
maplins must be pleased with this forum as i have also bought the A47FH.
fitted it to the roof of my megane estate at the rear offside corner.
signal strength is certainly better but i was a bit disappointed with the satellite lock times.
40 seconds with aerial
45 without
this is with batteries installed then powered from the car and keeping stationary until lock established.
don't know what i really expected but certainly a quicker lock time than that.
any views ??? |
simon78 Occasional Visitor
Joined: Mar 10, 2006 Posts: 24 Location: Lincolnshire
Posted: Wed Apr 19, 2006 8:43 pm Post subject: |
Quote: | signal strength is certainly better but i was a bit disappointed with the satellite lock times.
45 without
What's so bad about 40 seconds its not even length of time it takes to put seatbelt on and start your car
Why dony u turn it on as you walk to your car that way it will have picked up satalites by the time you get it plugged into aeriel  |
Posted: Wed Apr 19, 2006 9:22 pm Post subject: |
I found it seemed to get better each time I used it _________________ Ian Dee,
tommtom iphone6
bad elf TomTom25 |
Dilcymro Frequent Visitor
Posted: Wed Apr 19, 2006 9:43 pm Post subject: |
Evening all,
I think mine took about 30 secs the first time, haven`t taken much notice after that, by the time I have started up and seat belt on its locked on. Has anyone got a garmin one to compare? mind you for a tenner its swings and roundabouts isn`t it. _________________ ***************************************
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
Posted: Wed Apr 19, 2006 11:00 pm Post subject: |
iandee wrote: | I found it seemed to get better each time I used it |
that seems to be an interseting issue to raise.
as it takes its power from the i3 does the aerial need to "associate" itself ie settle down. thinking back to my cb radio days when the set and aerial had to be tuned in together.
must be a boffin or two out there who could shed some light. |
semaj Occasional Visitor
Posted: Thu Apr 20, 2006 8:58 pm Post subject: 206 |
I have mine in the rear window (inside)
Works great.
Unit sits in the space in front of the ash tray, cable runs behind and under back seat then up under center console out of ash tray. |
newtosatnav Regular Visitor
Posted: Fri Apr 21, 2006 10:14 pm Post subject: |
I have to say that the one I bought (from ebay - see the older posts) has a massive improvement on lock times and when I am in city the signal strength is massively improved. I have a C-Class Merc and there is an air vent on the top of the dash that is made of metal which the mag mount seems very happy to stick to! |
Posted: Sun Apr 23, 2006 9:00 pm Post subject: |
did a full reset on the little lady this afternoon, the first one since going back to beta 2.82
the sat lock times have now been reduced by about a third, now 20 to 30 secs
guess its like the wife really, a bunch of flowers and the worlds your lobster  |
Trajet Regular Visitor
Joined: Oct 04, 2005 Posts: 160 Location: Highlands of Scotland
Posted: Sun Apr 23, 2006 9:33 pm Post subject: |
matb wrote: | guess its like the wife really, a bunch of flowers and the worlds your lobster  |
Aw all red and nippy  |
GoHome Occasional Visitor
Posted: Mon Apr 24, 2006 7:35 am Post subject: |
Bought the I3 in December and have continually updated as an when they come out, also POI's and Speedcams, put my own Splashscreens on (thanks for the input from members for that one). I have never had a problem with the unit.................so why do I fix things when they are not broken?
So I have been reading with interest that you can getter better reception using the 9.99ukp arial from Maplins.
Got the arial from Maplins in Bradford on Saturday afternoon and tried it straight away by just plugging it in and putting the arial on to the back shelf of my Megane, then powered on WOW....! lock in a matter of seconds.
So Sunday fitted it a bit more permanant by placing under the trim and basically losing it from the sight of the little angels that roam our streets.
Sunday I decided to do a trip ..........arghhhh unit is frozen turned it off ....Tried again...........nothing.
So I have just had to do a hard reset. I had lost all my Favourites. I suppose that will teach me not to fix things that are not broken.
BTW no other problems with 2.9 and pleased with the better warnings.
John |
timber Frequent Visitor
Joined: Jan 18, 2006 Posts: 422 Location: Wild and Windy SW Scotland UK
Posted: Mon Apr 24, 2006 8:20 am Post subject: |
GoHome wrote: | Got the arial from Maplins in Bradford on Saturday afternoon and tried it straight away by just plugging it in and putting the arial on to the back shelf of my Megane, then powered on WOW....! lock in a matter of seconds.
John |
John its the Crap 2.90 software release which caused your problems, the arial has nothing to do with anything.
Put the beta 2.82 back on then await garmins 2.90 fixed release should not be far away. |
Posted: Mon Apr 24, 2006 7:24 pm Post subject: |
Quote: | John its the Crap 2.90 software release which caused your problems, the arial has nothing to do with anything.
No sure what you mean about the 2.90 software as I have 2.90 software on mine and have had no problems with it, I used it whilst on holiday and again no problems. Also have an external areial which works brilliantly. |
