ajith Occasional Visitor
Posted: Fri Mar 31, 2006 1:51 am Post subject: |
Hi Pal ,can i copy camera database to NAVIGATOR5 using a card reader?When i copied like this, its showing in the Great Britain Map File when i explore the SD memory content. But not coming when i run the Navigator or do i need to synchorinze my Pocket PC. I use Axim X30 ,Tomtom Navigator5.1 Help ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Fri Mar 31, 2006 7:23 am Post subject: |
Yes you can copy with a Card Reader. When you start TT it will re-read the contents of the Map Folder.
Have you more than 39 POI's in your Map Folder?
If you have less than that, have you set them up in Warn When Near? _________________ Richard
strayduck Occasional Visitor
Posted: Fri Mar 31, 2006 11:24 pm Post subject: |
hope that somebody can help
i have downloaded the camera database onto my tomtom which is run on a pda my problem is that although the program files are showing in my poi folder i have no icons and therefore no visible locations any idea as to why i am using tomtom nav 3 |
Mikeact Frequent Visitor
Joined: Nov 29, 2004 Posts: 303 Location: West Sussex
Posted: Sat Apr 01, 2006 12:05 am Post subject: |
'any idea as to why i am using tomtom nav 3'
Suggest you use TT5 instead. |
Posted: Sat Apr 01, 2006 12:17 am Post subject: |
strayduck wrote: | hope that somebody can help
i have downloaded the camera database onto my tomtom which is run on a pda my problem is that although the program files are showing in my poi folder i have no icons and therefore no visible locations any idea as to why i am using tomtom nav 3 | If you are using TT3 you will need CheckPOI vs3,2 it is available from this site in the downloads section CheckPOI you then need to configure this utility to work correctly, if you find problems please come back with a question, but it is some time since I used this application - Mike |
Posted: Sun Apr 02, 2006 4:05 pm Post subject: |
would like to use tt5 but unfortunately my pda isn't compatable with it |
Posted: Sun Apr 02, 2006 9:49 pm Post subject: |
i think i may have sussed it tried to drag and drop from the unzipped file to the map files one the storage card
seem to be working
i will let you know after a longer journey
thanks for the help |
d3m0n Occasional Visitor
Posted: Tue Apr 04, 2006 1:26 pm Post subject: |
d3m0n wrote: | rsvdaz wrote: | when you do an monthly update do you delete the previous download off the smartcard or does it simply overwrite? |
What if I'm moving from the old-style update (Jan 06) to the new-style all-encompassing update with all the cameras in?
Do I delete the old OV2 and BMP files from my map folder and set all the alerts, etc up again?
Cheers |
Hi can someone answer this for me please? Until now, I've left the old seperate files in place alongside the new files, and experienced some strange behaviour. Today I deleted the old files and reinstalled the new files (pocketgps_uk_sc.bmp and pocketgps_uk_sc.ov2) and set them up in POI management, but I only see one entry (PocketGPS UK SC). Is this right (as before, I had each individual entry for each type of camera)? By selecting this entry, will it warn me when ALL types of camera sites are near?
d3m0n |
Posted: Tue Apr 04, 2006 7:04 pm Post subject: |
d3m0n wrote: | By selecting this entry, will it warn me when ALL types of camera sites are near? |
The single File that you have contains all the Speed Cameras, but does not show the Type of Camera.
To be able to see the different type Cameras you will need to Download the Consolidated Set, which will show as 5 different types of Camera. _________________ Richard
mklion Occasional Visitor
Posted: Wed Apr 05, 2006 10:08 am Post subject: |
hi i've got a p910i sony erricsson phone and would like to get the speed cameras on it, but I dont see how to do this in simple terms.
all i want to do is drop a couple of files into a folder on my memory card but its not that simple, what with the files and programs your all talking about?
where can i d/load the specific files i need for this phone?
many thanks in advance, i've tried searching but its like a needle in a haystack. |
Posted: Wed Apr 05, 2006 8:13 pm Post subject: |
mklion wrote: | where can i d/load the specific files i need for this phone?
I'll assume it's TT5 you are using. In which case all you need to do is go to the Speed Cameras Page, and selecting TomTom OV2. In the next drop down list select which Camera Set you want to use.
Download this. Unzip the File. Copy the matching .ov2 and .bmp Files to the Map Folder on the SD Card. _________________ Richard
g0vax Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Posted: Fri Apr 21, 2006 10:46 am Post subject: transferring gb maps from 256mb to 1gb card??? |
Hi All,
Not sure if I'm in the right place here.
I have a Tomtom Mobile 5 system on my nokia N70 phone, I'd like to swap the files for the tomtom onto a 1gb card so I can put maps on for France,Holland and Germany.
HOW DO I DO IT????? AND WILL IT WORK??????
Best Wishes
Brian _________________ Brian G0VAX |
lupos0_1 Lifetime Member
![](modules/Forums/images/avatars/210896915648709d6ed5619.jpg)
Posted: Fri Apr 21, 2006 3:52 pm Post subject: |
Use a card reader.
First, backup your card (in case anythinggoes wrong)
Then just copy everything onto the new card. Make sure you select hidden files as well in the preferences. _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
welchy1992 Occasional Visitor
Posted: Sat Apr 22, 2006 11:29 pm Post subject: |
Hello everyone,
I have a pocket pc with tomtom 5 navigator installed on it but i have not got any POI's on the pc. Does any1 kno how 2 put them on
email back asap on welchy_1992@hotmail.co.uk
or
post a reply on this site
thanks welchy1992 |
Posted: Sun Apr 23, 2006 12:42 am Post subject: |
welchy1992 wrote: | Hello everyone,
or
thanks welchy1992 |
Suggest you do a search......there's loads of Q' and A's on this subject without going through it all again. |
