mfs227 Occasional Visitor
Posted: Thu Apr 20, 2006 12:37 pm Post subject: SD card upgrades for TT One |
I recently purchased a 512mb to replace the 128 card in my TT One. After coping the 128 card onto the 512 card and inserting it into the unit it would not accept the new card. After much hassel and a call to the TT Service Desk, the fault was discovered. The new card MUST be rated AT LEAST 10mbp/s. Those cheap large cards are not compatable as most are rated a 2-5mbp/s |
Tumbleweed Frequent Visitor
Posted: Thu Apr 20, 2006 12:55 pm Post subject: Re: SD card upgrades for TT One |
mfs227 wrote: | I recently purchased a 512mb to replace the 128 card in my TT One. After coping the 128 card onto the 512 card and inserting it into the unit it would not accept the new card. After much hassel and a call to the TT Service Desk, the fault was discovered. The new card MUST be rated AT LEAST 10mbp/s. Those cheap large cards are not compatable as most are rated a 2-5mbp/s |
Have you confirmed that by using a different card that you know is rated at 10MB ?
The card in my 300 is rated as 2Mb and is fine.
Tw |
MR_TiGGer Regular Visitor
Joined: Apr 20, 2006 Posts: 94 Location: God knows!! Ask Jane
Posted: Fri Apr 21, 2006 12:25 am Post subject: |
Maybe the TT1 being both newer and faster (I understand) may require a faster transfer rate??
I'm sure TT would know, but it's really good info as I've only just recieved my TT1 and was thinking the same, either half or a full one gig, save ever doing it again |
Posted: Fri Apr 21, 2006 12:20 pm Post subject: Re: SD card upgrades for TT One |
Tumbleweed wrote: | mfs227 wrote: | I recently purchased a 512mb to replace the 128 card in my TT One. After coping the 128 card onto the 512 card and inserting it into the unit it would not accept the new card. After much hassel and a call to the TT Service Desk, the fault was discovered. The new card MUST be rated AT LEAST 10mbp/s. Those cheap large cards are not compatable as most are rated a 2-5mbp/s |
Tw |
I noticed you have the 300. I don't think this applies to that model, however I did install a new card rated at 20mbp/s (512)and it worked great. The cpu in the TT One is faster than the 300 so guess that is where the difference is.
mfs227 |
Posted: Fri Apr 21, 2006 12:27 pm Post subject: |
MR_TiGGer wrote: | Maybe the TT1 being both newer and faster (I understand) may require a faster transfer rate??
Thats great, plus you will have room to add anything else you want. I have the full camera download with the different camera catagorys and will add the 7 didget post code search when I can find it.
Regards, mfs227 |
Andy_P Pocket GPS Moderator
Posted: Fri Apr 21, 2006 6:10 pm Post subject: |
mfs277 - if you've got a TT One, you should have the full postcode search already. Are you looking on the SECOND page of the "Navigate to..." menu, where "Postcode" is, don't try to enter it in "Address". |
Posted: Fri Apr 21, 2006 6:38 pm Post subject: |
Yup the 7 Digit postcode search is the reason I went for TT one .... and it fits in the pocket too of course.
You already set to "Do that seach" |
