ca6leguy Occasional Visitor
Posted: Sun Apr 16, 2006 11:55 pm Post subject: Navigating mode and tracking movement in CoPilot 6 |
What happened to the Navigating Mode in CoPilot 6? I want CoPilot to track my movement without having to plan a trip so that I can play it back later. Is this possible? |
SupraCoPilot Occasional Visitor
Posted: Mon Apr 17, 2006 11:34 am Post subject: Re: Navigating mode and tracking movement in CoPilot 6 |
ca6leguy wrote: | What happened to the Navigating Mode in CoPilot 6? I want CoPilot to track my movement without having to plan a trip so that I can play it back later. Is this possible? |
You can track your movement by selecting Walking mode and then select View/Where Am I. It doesn't appear to prompt to "Enter a stop for route guidance" as Planning and Guidance modes do. I'm not sure whether it will record the GPS track, but presume that it will do. _________________ Steve
Garmin Nuvi 255WT
Mio 168
CoPilot 6.0.4.110 |
Posted: Mon Apr 17, 2006 11:53 am Post subject: Re: Navigating mode and tracking movement in CoPilot 6 |
SupraCoPilot wrote: | ca6leguy wrote: | What happened to the Navigating Mode in CoPilot 6? I want CoPilot to track my movement without having to plan a trip so that I can play it back later. Is this possible? |
You can track your movement by selecting Walking mode and then select View/Where Am I. It doesn't appear to prompt to "Enter a stop for route guidance" as Planning and Guidance modes do. I'm not sure whether it will record the GPS track, but presume that it will do. |
Thanks for that, I'll give it a go. |
Posted: Mon Apr 17, 2006 12:03 pm Post subject: |
Is there a way to playback the tracks on the desktop PC? |
iankb Frequent Visitor
Joined: May 09, 2005 Posts: 283 Location: Reading, UK
Posted: Tue Apr 18, 2006 1:48 pm Post subject: |
ca6leguy wrote: | Is there a way to playback the tracks on the desktop PC? |
Yes, but not within CoPilot.
You can convert them (using GPS Babel) and import them into Google Earth. Dragging the Path from the Track folder into the Route folder will then allow you to fly the route. I find setting the view to 150 metres back, and 60% off the vertical, with (3D) Terrain enabled, and 3 times exaggeration of height, gives you a great view, as you fly down the valleys. _________________ Ian
iPaq 2210
Globalsat BT-338
Seidio G2500 Amplified Vent Mount
CoPilot 6, GPS Tuner 4.2, Navio 3.01
BMW 330ci Sport |
Posted: Wed Apr 19, 2006 5:02 am Post subject: |
iankb wrote: |
You can convert them (using GPS Babel) and import them into Google Earth. |
Are you talking about Google Earth or Google Earth Plus? |
Posted: Wed Apr 19, 2006 5:40 am Post subject: |
Google Earth - the free one. It's a bit misleading when it says that you need Google Earth Plus to read track files.
You can open GPX files, and GPS Babel can convert CP6 track files into GPX files. _________________ Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport |
Posted: Wed Apr 19, 2006 11:11 am Post subject: |
iankb wrote: | Google Earth - the free one. It's a bit misleading when it says that you need Google Earth Plus to read track files.
You can open GPX files, and GPS Babel can convert CP6 track files into GPX files. |
I can't seem to get it to work. What input and output file format do you use? |
Posted: Wed Apr 19, 2006 12:30 pm Post subject: |
ca6leguy wrote: | iankb wrote: | Google Earth - the free one. It's a bit misleading when it says that you need Google Earth Plus to read track files.
It's ok, I managed to get it working. Really look good on Google Earth. Thanks. |
Posted: Wed Apr 19, 2006 1:06 pm Post subject: Re: Navigating mode and tracking movement in CoPilot 6 |
Looks like it does not record the GPS track when in walking mode. |
PONDEROUS Frequent Visitor
Joined: Aug 25, 2004 Posts: 634 Location: Lincolnshire, England
Posted: Wed Apr 19, 2006 10:17 pm Post subject: |
Visual GPS CE may be of interest. This utility records a GPS log which I expect might be usable with some of the playback utilities mentioned by others , although I haven’t used it for that purpose as yet.
The utility is available free of charge and can be downloaded from:
http://www.visualgps.net/VisualGPSce/ _________________ Dell Axims X50v & X30 (both WM 2003 2nd Edition). Copilot BTGPS3 and Fortuna Clip-on BT receivers. Jabra BT 250 audio headsets. Welltech 40032/AF32 BT handsfree audio. Copilot 6.0.4.110. TomTom Navigator 5.21. MS Autoroute/Pocket Streets 2005 |
Posted: Thu Apr 20, 2006 12:32 am Post subject: Re: Navigating mode and tracking movement in CoPilot 6 |
ca6leguy wrote: | Looks like it does not record the GPS track when in walking mode. |
I did another test today, and can confirm that it records the GPS track in walking mode. Thanks and sorry for all the questions. I'm still new with this |
