Snowflame Occasional Visitor
Posted: Tue Apr 18, 2006 2:43 pm Post subject: Earlier Warning at Roundabouts |
Being a newbie to this Forum this may have been mentioned before. I have just started using the i2 and was very impressed. However when approaching a roundabout which has several lanes leading up to it, it does leave it rather late before it informs you which exit you should take. Changing lanes at such late notice can cause problems. Oddley enough when I was approaching a roundabout recently with only 1 lane it gave me 0.4 of a mile notice of the exit!!
And finally, where can I get the most up to date street maps or is the Garmin website the best place to obtain these? |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Tue Apr 18, 2006 3:02 pm Post subject: |
hello mate...check to see what version firmware you are running...version 2.9 has ''improved the timing of voice guidence prompts'' so that might solve your problem...again check what version mapping you have, version 8 is the most uptodate....lastly how good is the b&w screen on the i2... _________________ *************************** |
Posted: Tue Apr 18, 2006 3:31 pm Post subject: |
Thanks for replying zogman. I have v2.9 and map v8. The mono screen is fine - you don't really need the colour version and its cheaper by around £40 to £50 squid!! |
Posted: Tue Apr 18, 2006 3:52 pm Post subject: |
with v2.9 firmware and v8 maps you've got the most up to date setup...the timing of the alerts might just be a quirk in that particular area.... _________________ *************************** |
Posted: Tue Apr 18, 2006 4:35 pm Post subject: |
Quote: | you don't really need the colour version |
True but it easier to watch the i3's built in TV Tuner when stuck in traffic if you have the colour screen. |
Posted: Tue Apr 18, 2006 4:38 pm Post subject: |
tried to put a dvd into the card slot but it dont fit,,any ideas !.. _________________ *************************** |
Posted: Tue Apr 18, 2006 4:40 pm Post subject: |
I know this could be a daft suggestion but could it speed related. EG if I approached a roundabout a bit on the quick side - could this affect the timing of the alert? |
Posted: Tue Apr 18, 2006 4:53 pm Post subject: |
PaulB2005: Yes, I can only watch old B&W programs. I have however been able to download the patch to make my i2 HD ready !!
You too can get this from WWW.UMUSTBHAVINGALAF.COM.
Posted: Tue Apr 18, 2006 5:32 pm Post subject: |
Quote: | I know this could be a daft suggestion but could it speed related. EG if I approached a roundabout a bit on the quick side - could this affect the timing of the alert? |
How fast where you approaching the roundabout? It could do i suppose. I did initially think the warnings where better under the 2.9 but since going back to 2.7 i struggle to notice the difference. |
dougconran Regular Visitor
Joined: Oct 07, 2004 Posts: 175 Location: Bury St Edmunds, Suffolk
Posted: Tue Apr 18, 2006 8:31 pm Post subject: |
There seems to be a cutover point at about 30mph where the final instructions to turn at a normal road junction are given much closer to the turn in question. Below that speed I generally (but not, not always) get the final instruction considerably closer to the point of turn, probably less than 100m whereas going above 30-40mph I generally get the final instruction about 300m before the turn. I'd guess it is the same for roundabouts.
What I find frustrating is that it does not appear to be consistent (at least, I haven't yet worked out what the consistency is )
I'm using v2.7 and v7 maps. |
BAVC10 Lifetime Member
Posted: Tue Apr 18, 2006 9:14 pm Post subject: |
PaulB2005
I posted a note on a different 2.90 thread re the differences between 2.70 and 2.90. I had two i3s side by side and 2.90 voice prompts were earlier by 2 seconds at most - irrespective of whether it was a motorway junction or housing estate. |
Posted: Wed Apr 19, 2006 8:51 am Post subject: |
Cheers. Having now gone back to 2.7 (twice) i can't really see that 2.7 was that bad / different. |
ride4smilesjonny Regular Visitor
Posted: Wed Apr 19, 2006 4:44 pm Post subject: |
zogman wrote: | tried to put a dvd into the card slot but it dont fit,,any ideas !.. |
Try a 12" bladed stihl saw zoggy, carefully butcher the sides off of the required dvd and hey presto, it still dont work 8O _________________ **********************************
Hi ho - Hi ho its off to Arran i go,
with my i3 and a cup of tea hi ho, hi ho
hi ho hi ho.....
www.ride4smiles.co.uk
£3500 raised in two weeks! :-) |
Posted: Wed Apr 19, 2006 5:02 pm Post subject: |
ride4smilesjonny wrote: |
Try a 12" bladed stihl saw zoggy, carefully butcher the sides off of the required dvd and hey presto, it still dont work 8O |
he he he............i wonder if lester knows how to it........ _________________ *************************** |
Lester_Burnham Frequent Visitor
Posted: Wed Apr 19, 2006 5:24 pm Post subject: |
zogman wrote: | ride4smilesjonny wrote: |
he he he............i wonder if lester knows how to it........ |
Indeed I do...
See by sawing off the sides of the DVD, you did indeed reduce the resolution from D1 to something the i3 could display.
And, whazzing of the sides of the deev, did indeed reduced the bitrate of the video and audio from DVD spec, to something more acceptable for the i3.
However, the rather crude method of sawing through the disk, rather than using a phased plasma rifle in the 40 watt range, meant that all the bits have just spilled out from the sides of the disk.
If you're gonna do it, at least do it properly, sheesh! What you should have done, in the absence of have said plasma rifle, is stick the deev in your bestest, most powerful microwave oven. Make sure it's on full power, and cook that deev down to size...
Lester (for all your video conversion needs, and available for after-dinner speeches and bar mitzvahs) |
