Rich Regular Visitor
Posted: Wed Nov 12, 2003 1:46 am Post subject: Yakumo PDA delta 400 with TT2 |
Hi by any chance if anyone knows whether Yakumo PDA delta 400 compatible with tomtom2 navigator 2 with GB map?
Or should I say, how do I know what TT2 not compatible with?
http://www.yakumo.com/produkte/index.php?pid=2&artnr=1022607
Thanks,
Rich |
lbendlin Pocket GPS Staff
Posted: Wed Nov 12, 2003 3:08 am Post subject: |
Yes, that machine certainly is compatible with TT2. check here: http://www.chip.de/artikel/c_artikelunterseite_10663784.html
Generally it's not so much a question if TT is compatible with it (TT plays with all ARM/PXA, MIPS and SH3 processors), it is more if the PDA has a usable GPS interface (serial, CF or BlueTooth). As far as I know there is no SD or USB based interface out there yet. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed Nov 12, 2003 10:54 pm Post subject: |
Hi Lutz, sorry that I am not so technical. When you said there is not SD or USB interface, what does it mean? What kind of problem I am likely to have? Do you mean the problem is likely to be between the receiver and the pda instead of the pda and the software?
Thanks again,
Rich |
Posted: Thu Nov 13, 2003 12:45 am Post subject: |
That is correct. It is more about gettint the PDA and the receiver to talk to each other. From there it is an easy step because most of the current applications support NMEA and SIRF on any of the most common COM ports (be it real or virtual COM ports) _________________ Lutz
