atc Occasional Visitor
Posted: Sat Apr 15, 2006 11:12 am Post subject: losing memory? |
Using a navman 610 and have had it just over a year. Only recently what it’s been doing is during a journey it stops s showing the maps and says loading map in the centre of the screen. When it goes back onto the map screen no map is there but the arrow for the car is there the GPS signal is strong and it tells you to go to the nearest road. This is only started to do it. I don’t use the sat-nav every day but when I do it happens every half an hour or so. Has anyone had the same problem and how do you fix it |
Posted: Sat Apr 15, 2006 1:12 pm Post subject: re memory lost? |
forget to say when you switch the navman off /on its ok for a short time then it happens again |
spin36 Occasional Visitor
Posted: Sun Apr 16, 2006 11:06 am Post subject: |
have you try cleaning the copper ends of the SD card. |
Posted: Sun Apr 16, 2006 1:17 pm Post subject: tried it first |
yes. The first thing i did also i blown out the slot just in case there were some dust inside. Thanks anymore ideas. |
Posted: Sun Apr 16, 2006 5:33 pm Post subject: |
at a long shoot have you formated the SD card and reinstall the maps |
Posted: Mon Apr 17, 2006 8:49 pm Post subject: thanks |
just check and i bought the navman just under a year.
Took it back to shop and they replace it. Only thing is that they change it with a tomtom 300 as it was the same price now as the navman 610 was and all the navmans were all under £200 and i wanted my money worth. Thanks for the help anyway |
