Darren Frequent Visitor
Posted: Sat Apr 08, 2006 7:38 pm Post subject: TomTom RIDER Install - Honda ST1100 Pan European |
I've just installed a RIDER on my ST1100P, I haven't got around to installing a 12v feed but for those that are interested I've used one of the bracket's supplied albeit reversed to install it on the instrument surround.
_________________ Darren Griffin |
gpsn3wbie Regular Visitor
Posted: Mon Apr 10, 2006 12:15 pm Post subject: |
looks good there mate. wish i could afford one |
StevenGourlay Frequent Visitor
Posted: Tue Apr 11, 2006 4:57 pm Post subject: |
Yeah nice pictures, as i said get some reflective strips and some blue lights. _________________ Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool |
Posted: Tue Apr 11, 2006 5:11 pm Post subject: |
StevenGourlay wrote: | Yeah nice pictures, as i said get some reflective strips and some blue lights. |
No thanks, been there, done that, got the certificate ;) _________________ Darren Griffin |
Gmonkey Frequent Visitor
Joined: Oct 17, 2005 Posts: 390 Location: Washington DC
Posted: Tue Apr 11, 2006 9:25 pm Post subject: |
Quote: | I've just installed a RIDER on my ST1100P, I haven't got around to installing a 12v feed but for those that are interested I've used one of the bracket's supplied albeit reversed to install it on the instrument surround. |
Great shots, Darren. The rider really looks like a good fit there. |
Posted: Tue Apr 11, 2006 9:38 pm Post subject: |
The only problem is the BT headset. It's poorly designed with not enough cable and too thin. It's inaudible above 50mph and it won't be long before i snag it and it breaks. _________________ Darren Griffin |
Posted: Wed Apr 12, 2006 10:38 am Post subject: |
Yeah i would have to agree, i aslo would have prefered having the option of stereo sound. _________________ Regards
Steven Gourlay
Posted: Thu Apr 13, 2006 1:04 am Post subject: |
Quote: | The only problem is the BT headset. It's poorly designed with not enough cable and too thin. It's inaudible above 50mph and it won't be long before i snag it and it breaks. |
How much cable do they give you?
How thin is the wire? |
Posted: Thu Apr 13, 2006 2:43 pm Post subject: |
The headset speaker is velcro backed and has about 4" of cable between it and the microphone which in turn has 1" of cable before the 2.5mm jack.
This isn't really enough to allow sensible placing of the Microphone as if you have the mic at the front it means the jack plug has to exit the helmet at the front!
There is then an extension that connects this to the BT receiver.
The cable is very thin, such as you would find in cheap earphones. _________________ Darren Griffin |
dazzajones Occasional Visitor
Posted: Thu Apr 13, 2006 8:26 pm Post subject: |
i wish there was a direct replacement 2.5mm helmet speaker set we could use instead. Tiz poop! |
Courierman Regular Visitor
Joined: Jun 08, 2004 Posts: 88 Location: Chatham Kent
Posted: Fri Apr 14, 2006 9:15 pm Post subject: |
Darren wrote: | The headset speaker is velcro backed and has about 4" of cable between it and the microphone which in turn has 1" of cable before the 2.5mm jack.
The cable is very thin, such as you would find in cheap earphones. |
have you made a loop
so the mike is at the front and the jack is at the back
O----------|
jack *----o
Posted: Mon Apr 17, 2006 5:28 pm Post subject: |
Courierman wrote: | have you made a loop
O----------|
jack *----o |
That's the problem, there isn't enough cable to make a loop as I would like it. _________________ Darren Griffin |
bigfatjohn Regular Visitor
Joined: Oct 29, 2003 Posts: 114 Location: Market Harborough
Posted: Tue Apr 18, 2006 4:09 am Post subject: |
That's a neat enough installation Darren.
I've done something similar on my Wing, except that I've screwed my bracket underneath the lip of the dash, rather than on top. |
Posted: Tue Apr 18, 2006 1:06 pm Post subject: |
Darren wrote: | Courierman wrote: | have you made a loop
O----------|
jack *----o |
That's the problem, there isn't enough cable to make a loop as I would like it. |
Hi ya how good are you with a soldering iron ??
First get an old pear old headphones cut the wire to suite
Next bear the wire and use a multi meter check which wires go which pole on the connector make a note
Next the bear the wire on the TT headphones DON’T cut Yet, use a multi meter check which wires go which pole on the connector make a note
Next cut at a angel so that the 2 wires are off set (there will be a earth for each one) 1 long 1 short
Next from your notes do the same to the other wires BUT opposite
Next put 1 large peace of shrink wrap over the long peace of wire then the 4 smaller peaces solder all 8 wires heat the 4 smaller peaces shrink wrap, pull over them the large peace and heat it to cover your work
Things you’ll is 2 lots off heat shrink wrap from Maplins for the inner and outer wires
Posted: Tue Apr 18, 2006 1:22 pm Post subject: |
I'm ok with a soldering iron so I'm going to go one better and modify the speakers and boom mic from my old job lid to work. The only issue is the impedance of the mic and helmet speakers, but as they're gathering dust I've nowt to lose _________________ Darren Griffin |
