smiddyboy Occasional Visitor
Posted: Wed Apr 05, 2006 12:35 pm Post subject: Dell Axim x51v with TomTom Navgator wired GPS |
Hi there,
I am just new here so be kind!
I have just got a new Dell Axim x51v from work and my boss has gone and gotten a wired GPS receiver from TomTom with Navigator 5 ( he seems to have a grudge against bluetooth!)
I can't get the PDA to find the GPS receiver( it keeps coming up 'No GPS Device').
Had a look on the TomTom website and it looks as if it may not be compatible...is this true, or have any of you geniuses out there found out away around the problem.
Thanks in advance for any help |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Wed Apr 05, 2006 1:37 pm Post subject: |
Welcome to the forum, I am mobile at the moment so can't provide the direct link, if you use the search function and type in x51v it will find a number of threads covering GPS related issues with your device, there is one thread that used a reg edit to fix the unit and get it working - if this doesn't work or you can't find it please re-post and I will get back to you later - Mike |
Posted: Thu Apr 06, 2006 9:39 am Post subject: |
Mike,
Thanks for that. Found the thread with instructions for the registry tweak and that has done the trick..Magic! :D
I knew i came to the right place!
Smiddy. |
eruisi Occasional Visitor
Posted: Fri Apr 14, 2006 3:15 am Post subject: |
Can you provide the link? I couldn't find it.
Thanks a lot!
mikealder wrote: | Welcome to the forum, I am mobile at the moment so can't provide the direct link, if you use the search function and type in x51v it will find a number of threads covering GPS related issues with your device, there is one thread that used a reg edit to fix the unit and get it working - if this doesn't work or you can't find it please re-post and I will get back to you later - Mike |
