Pocket GPS World :: View topic - Navman 510 screen Froze & wont respond
sintra
PostPosted: Mon Apr 10, 2006 7:22 pm    Post subject: Navman 510 screen Froze & wont respond Reply with quote
Hi, I'm new to these gadgets, my Navman 510 was working perfect until I downloaded the link for speed camera's, it shows the file went in and since then my Navman has froze and doesn’t even respond to the touch screen, when I connect it to the computer via the USB cable it doesn’t respond and wont synchronize with computer, have phoned Navman Tech Support and get Question Idea try downloading the up-date & still nothing happens?
Can anyone HELP!!!! Laughing
PostPosted: Tue Apr 11, 2006 4:30 pm    Post subject: Reply with quote
Have you tried a soft or hard reset?
sintra
PostPosted: Tue Apr 11, 2006 7:51 pm    Post subject: Reply with quote
Have tried both and dos'nt do anything Question
PostPosted: Tue Apr 11, 2006 8:05 pm    Post subject: Reply with quote
What happens when you switch on after the hard reset with the SD card removed?
sintra
PostPosted: Tue Apr 11, 2006 9:25 pm    Post subject: Reply with quote
Hi, Darren, Thanks for your reply, What is a Hard/ Soft Reset? If I turn the unit on from the back without the SD in, it boots up and then stays on the Navman ST Screen?
Regards, Sintra.
PostPosted: Tue Apr 11, 2006 9:40 pm    Post subject: Reply with quote
A soft reset is one where you insert the stylus into the 'reset' hole. This does not alter anuthing but gives it a nudge so to speak.
A hard reset by turning off the unit using the On/OFF slider on the rear turns the unit completely off and resets it to factory default. When turned on it re-installs afresh.
Give the hard reset a go.
sintra
PostPosted: Tue Apr 11, 2006 11:24 pm    Post subject: Reply with quote
Darren thanks again, I have tried both resets, Ive been on the navman website and tried to download the updated software as navman suggested but still no luck. The actual unit was working perfectly the other day until I downloaded the speed cameras and now the set is not responding at all. Any more suggestions would be a great help, cheers Sintra
PostPosted: Wed Apr 12, 2006 7:45 am    Post subject: Reply with quote
The only thing I can suggest is re-loading the software onto the SD card using SmartST desktop.
sintra
PostPosted: Wed Apr 12, 2006 11:44 am    Post subject: Reply with quote
Hi, Darren have been in touch with Navman and have sorted it out,
Thank God Laughing
But thanks for your help Thumbs Up
Sintra.
PostPosted: Wed Apr 12, 2006 11:50 am    Post subject: Reply with quote
Thank God Laughing
Sintra.
For the benefit of us all, what was the solution?
22.064 (26 Jun 24)
