sintra Occasional Visitor
Posted: Mon Apr 10, 2006 7:22 pm Post subject: Navman 510 screen Froze & wont respond |
Hi, I'm new to these gadgets, my Navman 510 was working perfect until I downloaded the link for speed camera's, it shows the file went in and since then my Navman has froze and doesn’t even respond to the touch screen, when I connect it to the computer via the USB cable it doesn’t respond and wont synchronize with computer, have phoned Navman Tech Support and get try downloading the up-date & still nothing happens?
Can anyone HELP!!!!
Darren Frequent Visitor
Posted: Tue Apr 11, 2006 4:30 pm Post subject: |
Have you tried a soft or hard reset? _________________ Darren Griffin |
Posted: Tue Apr 11, 2006 7:51 pm Post subject: |
Darren wrote: | Have you tried a soft or hard reset? |
Have tried both and dos'nt do anything ![Question](modules/Forums/images/smiles/icon_question.gif) |
Posted: Tue Apr 11, 2006 8:05 pm Post subject: |
What happens when you switch on after the hard reset with the SD card removed? _________________ Darren Griffin |
Posted: Tue Apr 11, 2006 9:25 pm Post subject: |
Darren wrote: | What happens when you switch on after the hard reset with the SD card removed? |
Hi, Darren, Thanks for your reply, What is a Hard/ Soft Reset? If I turn the unit on from the back without the SD in, it boots up and then stays on the Navman ST Screen?
Regards, Sintra. |
Posted: Tue Apr 11, 2006 9:40 pm Post subject: |
A soft reset is one where you insert the stylus into the 'reset' hole. This does not alter anuthing but gives it a nudge so to speak.
A hard reset by turning off the unit using the On/OFF slider on the rear turns the unit completely off and resets it to factory default. When turned on it re-installs afresh.
Give the hard reset a go. _________________ Darren Griffin |
Posted: Tue Apr 11, 2006 11:24 pm Post subject: |
Darren wrote: | A soft reset is one where you insert the stylus into the 'reset' hole. This does not alter anuthing but gives it a nudge so to speak.
Give the hard reset a go. |
Darren thanks again, I have tried both resets, Ive been on the navman website and tried to download the updated software as navman suggested but still no luck. The actual unit was working perfectly the other day until I downloaded the speed cameras and now the set is not responding at all. Any more suggestions would be a great help, cheers Sintra |
Posted: Wed Apr 12, 2006 7:45 am Post subject: |
The only thing I can suggest is re-loading the software onto the SD card using SmartST desktop. _________________ Darren Griffin |
Posted: Wed Apr 12, 2006 11:44 am Post subject: |
Hi, Darren have been in touch with Navman and have sorted it out,
Thank God
But thanks for your help
Sintra. |
Posted: Wed Apr 12, 2006 11:50 am Post subject: |
sintra wrote: | Hi, Darren have been in touch with Navman and have sorted it out,
Thank God
Sintra. |
For the benefit of us all, what was the solution? _________________ Darren Griffin |
