Pocket GPS World :: View topic - TomTom RIDER Install - Honda ST1100 Pan European
PostPosted: Sat Apr 08, 2006 7:38 pm    Post subject: TomTom RIDER Install - Honda ST1100 Pan European Reply with quote
I've just installed a RIDER on my ST1100P, I haven't got around to installing a 12v feed but for those that are interested I've used one of the bracket's supplied albeit reversed to install it on the instrument surround.
gpsn3wbie
PostPosted: Mon Apr 10, 2006 12:15 pm    Post subject: Reply with quote
looks good there mate. wish i could afford one Mr. Green
StevenGourlay
PostPosted: Tue Apr 11, 2006 4:57 pm    Post subject: Reply with quote
Yeah nice pictures, as i said get some reflective strips and some blue lights. Laughing Laughing
Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool
PostPosted: Tue Apr 11, 2006 5:11 pm    Post subject: Reply with quote
No thanks, been there, done that, got the certificate ;)
Gmonkey
PostPosted: Tue Apr 11, 2006 9:25 pm    Post subject: Reply with quote
Great shots, Darren. The rider really looks like a good fit there.
PostPosted: Tue Apr 11, 2006 9:38 pm    Post subject: Reply with quote
The only problem is the BT headset. It's poorly designed with not enough cable and too thin. It's inaudible above 50mph and it won't be long before i snag it and it breaks.
StevenGourlay
PostPosted: Wed Apr 12, 2006 10:38 am    Post subject: Reply with quote
Yeah i would have to agree, i aslo would have prefered having the option of stereo sound.
Regards
Steven Gourlay
Gmonkey
PostPosted: Thu Apr 13, 2006 1:04 am    Post subject: Reply with quote
How much cable do they give you?
How thin is the wire?
PostPosted: Thu Apr 13, 2006 2:43 pm    Post subject: Reply with quote
The headset speaker is velcro backed and has about 4" of cable between it and the microphone which in turn has 1" of cable before the 2.5mm jack.
This isn't really enough to allow sensible placing of the Microphone as if you have the mic at the front it means the jack plug has to exit the helmet at the front!
There is then an extension that connects this to the BT receiver.
The cable is very thin, such as you would find in cheap earphones.
dazzajones
PostPosted: Thu Apr 13, 2006 8:26 pm    Post subject: Reply with quote
i wish there was a direct replacement 2.5mm helmet speaker set we could use instead. Tiz poop!
Courierman
PostPosted: Fri Apr 14, 2006 9:15 pm    Post subject: Reply with quote
have you made a loop
so the mike is at the front and the jack is at the back
O----------|
jack *----o
PostPosted: Mon Apr 17, 2006 5:28 pm    Post subject: Reply with quote
O----------|
jack *----o
That's the problem, there isn't enough cable to make a loop as I would like it.
bigfatjohn
PostPosted: Tue Apr 18, 2006 4:09 am    Post subject: Reply with quote
That's a neat enough installation Darren.
I've done something similar on my Wing, except that I've screwed my bracket underneath the lip of the dash, rather than on top.
Courierman
PostPosted: Tue Apr 18, 2006 1:06 pm    Post subject: Reply with quote
O----------|
jack *----o
Hi ya how good are you with a soldering iron ??
First get an old pear old headphones cut the wire to suite
Next bear the wire and use a multi meter check which wires go which pole on the connector make a note
Next the bear the wire on the TT headphones DON’T cut Yet, use a multi meter check which wires go which pole on the connector make a note
Next cut at a angel so that the 2 wires are off set (there will be a earth for each one) 1 long 1 short
Next from your notes do the same to the other wires BUT opposite
Next put 1 large peace of shrink wrap over the long peace of wire then the 4 smaller peaces solder all 8 wires heat the 4 smaller peaces shrink wrap, pull over them the large peace and heat it to cover your work
Things you’ll is 2 lots off heat shrink wrap from Maplins for the inner and outer wires
PostPosted: Tue Apr 18, 2006 1:22 pm    Post subject: Reply with quote
I'm ok with a soldering iron so I'm going to go one better and modify the speakers and boom mic from my old job lid to work. The only issue is the impedance of the mic and helmet speakers, but as they're gathering dust I've nowt to lose Smile
23.012 (08 Jan 25)
