matb Frequent Visitor
Posted: Sun Apr 09, 2006 2:43 pm Post subject: |
StellaMaris wrote: | When upgrading to 2.9 with webupdater, that itself got updated. I then used Webupdater for a second time and it suggested that there may be more updates. There were additional voices, so I downloaded them anyway. Again I ran Webupdater and found again that there were more voice updates.
I wonder if you need to do this several times because after the third time, I did get, no further updates available.
Voice has also been updated. It was 2.10, but on checking again it now says version 2.00?!!
Not sure what heppened there..... |
i noticed this aswell. unfortunately on the second run the download went wrong, the i3 crashed.
when i rebooted it the language had changed to nederlands (belgie).
i checked all the other settings after reselecting english, there were no other changes made. |
Montala Regular Visitor
Posted: Sun Apr 09, 2006 3:22 pm Post subject: |
I have a copy of 2.7 I would be happy to email to anyone who wants to revert to that version... not too many requests though please! |
trevf Regular Visitor
Posted: Sun Apr 09, 2006 4:07 pm Post subject: |
trevf wrote: | BAVC10 wrote: | Trevf
Suggest you e-mail Garmin's Tech Support. If enough of us report the problems they may post 2.70 back on the update page until they work on a fix. I didn't experience the blank screen or delayed map update with beta 2.82 so something seems to have happened with 2.90 | I have done that. Hopefully something will happen:S | I'm not sure if this is the case or not but it seems to be... If I change GPS mode to Normal instead og WAAS / EGNOS I seem to be getting much better refreshes. Also I'm not sure but the problem only really seems to be happening on one stretch of road and Roundabout... I drive these everyday and have never noticed a problem before. Is it possible for a GPS signal to degrade in a (small) area? Anyone else noticed this or is it just me imagining things? |
sunstrip_steve Regular Visitor
Posted: Sun Apr 09, 2006 5:38 pm Post subject: |
Quote: |
when i rebooted it the language had changed to nederlands (belgie). |
Mine did the same, but spanish. would have been good had i noticed before driving! |
Pete7049 Occasional Visitor
Joined: Oct 15, 2005 Posts: 27 Location: Stevenage Herts
Posted: Sun Apr 09, 2006 5:43 pm Post subject: |
Hi all. So does the hard reset solve the screen problem??? Also, if you want to save your favorites, use this free prog: http://www.easygps.com/ . Thank you Easy GPS, you've saved me hours of spinning the wheel, ooo blisters! :D |
saudidave Regular Visitor
Joined: Apr 03, 2006 Posts: 99 Location: Poynton, Cheshire
Posted: Sun Apr 09, 2006 9:55 pm Post subject: |
I only bought my i3 a week ago loaded with 2.70 and loaded 2.90 yesterday. It now tells me to turn well before a junction, sometimes as much as 0.5 miles before. This can't be right! My only other observation (both V2.70 & 2.90) is that the accuracy is nowhere near as good as tom tom. With tom tom, I could accurately assess the road to turn in to as it counted down. The i3 can be 50 feet out. I know the i3 is way cheaper and I like it a lot, but it seems a little haphazard. |
Posted: Sun Apr 09, 2006 10:04 pm Post subject: |
i have found that if you use the voice prompts as a guide when to look at the screen it works quite well.
a "turn left" prompt near my house actually means second left. by looking at the screen the issue was resolved.
also bare in mind that if the junction is complicated ie a roundabout the dynamic zoom will come in to play and a quick glance will help. |
Posted: Sun Apr 09, 2006 10:11 pm Post subject: |
The increase distance voice warning of turns is much better than 2.70, however, it does depend of the type or turn. eg Mway junctions or turns with multiple lanes it allows you to select the correct lane safely at an appropriate distance ahead. I found this an issue with 2.70 |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Sun Apr 09, 2006 11:22 pm Post subject: |
saudidave wrote: | The i3 can be 50 feet out. I know the i3 is way cheaper and I like it a lot, but it seems a little haphazard. |
do you have WAAS / EGNOS turned on? this should help. |
Posted: Sun Apr 09, 2006 11:37 pm Post subject: |
MaFt wrote: | saudidave wrote: | The i3 can be 50 feet out. I know the i3 is way cheaper and I like it a lot, but it seems a little haphazard. |
What is WAAS/EGNOS? |
Posted: Sun Apr 09, 2006 11:44 pm Post subject: |
matb wrote: | i have found that if you use the voice prompts as a guide when to look at the screen it works quite well.
I am 53 years old and as is common at that age, I am long sighted. Looking at the screen helps sometimes but often it's not clear enough on an i3 |
kartracer Frequent Visitor
Joined: 26/03/2003 20:15:33 Posts: 502 Location: United Kingdom
Posted: Sun Apr 09, 2006 11:47 pm Post subject: |
trevf wrote: | Is it possible for a GPS signal to degrade in a (small) area? | It is quite possible to get poor GPS reception in a small area. I have seen the signals go haywire in the vicinity of the Rugby radio transmission site. And of course, the signals may be deliberately disrupted in selected areas by the military. _________________ Kam |
Posted: Mon Apr 10, 2006 12:44 am Post subject: |
I've sussed out WAAS & understand it now. I have turned it on and it makes a difference |
Posted: Mon Apr 10, 2006 12:47 am Post subject: |
BAVC10 Lifetime Member
