Pocket GPS World :: View topic - i3 V2.90 now avail from Garmin.
Goto page Previous  1, 2, 3, ... 12, 13, 14  Next
Technonot
PostPosted: Fri Apr 07, 2006 10:39 pm    Post subject: Reply with quote
Just updated to latest software - HELP ! i3 has died, is there any way to do a master reset ?
Technonot
PostPosted: Fri Apr 07, 2006 11:15 pm    Post subject: Reply with quote
Have found out how to do a master reset, i3 still dead, looks like I will be ringing Garmin next week !
(software must be iffy as I have carried out updates before with no problems).
Montala
PostPosted: Fri Apr 07, 2006 11:33 pm    Post subject: Reply with quote
Sorry to hear you are having problems. Out of interest did you use the latest Web Updater, or did you update the software 'manually'?
I have just updated two units (one for a friend) using the Web Updater without any problems. It did take a bit longer than I expected though, and it is important to wait until it actually tells you that it has completed the upgrade, before unplugging the device.
That's not much help to you now though... I presume you have tried plugging the i3 into your PC again and then turning it on?
Aitch2
PostPosted: Fri Apr 07, 2006 11:56 pm    Post subject: Reply with quote
...and I can't update at all - lost my USB lead (again) - booger! Crying or Very sad
Aitch
Find Somewhere Else 090407: www.marillion.com
kartracer
PostPosted: Sat Apr 08, 2006 8:24 am    Post subject: Reply with quote
Haven't you got another one sitting around somewhere, say from a digital camera?
Kam
Technonot
PostPosted: Sat Apr 08, 2006 9:16 am    Post subject: Reply with quote
Montala :
Used the latest Web Updater, unit still dead this morning !.
PaulB2005
PostPosted: Sat Apr 08, 2006 9:23 am    Post subject: Reply with quote
Just updated to 2.9. Voice Turn Commands are MUCH better....
PostPosted: Sat Apr 08, 2006 10:09 am    Post subject: Reply with quote
about time they corrected the bug when searching in custom points sub-folders - finally, it actually functions!
attic
PostPosted: Sat Apr 08, 2006 10:31 am    Post subject: Issue with new version Reply with quote
I just updated to 2.9 (and new web updater).
When I click "where to", as well as the usual annoying list of countries, it now give Belgium spelled in 3 languages and Wales, Channel islands, Holland and norway in 2.
Does anyone else have this?
More importantly, does anyone know how to get rid of it?
I tried changing the language to French then back to english, but same thing...
Montala
PostPosted: Sat Apr 08, 2006 10:38 am    Post subject: Reply with quote
That doesn't sound too encouraging!
As you mentioned, you could contact Garmin directly, but I would have thought you might be better off just returning the unit to the place of purchase, and seeing if you can get them to exchange it under warranty.
Good luck anyway!
alan_t
PostPosted: Sat Apr 08, 2006 12:16 pm    Post subject: Reply with quote
just updated here with no probs.
PaulB2005
PostPosted: Sat Apr 08, 2006 12:28 pm    Post subject: Reply with quote
Anyone else feels the unit is faster as a whole?
I have a Renault Megane with a Thermal Windscreen so i have an Antenna which runs to the rear parcel-shelf. I also back my car in to the drive so when i get in the car the antenna is in a poor reception area with the house right behind it. I usually find it takes about 45-60 seconds to get a lock. I then discover i can cut this to 30 seconds if i move a few feet up the drive.
Today after 2.9 Firmware upgrade it got lock in under 10 seconds without having moved the car. When i first got the i3 it took me 20 minutes to get the first lock in the garden after flashing from 2.6 to 2.7. It then got a lock in under 2 seconds in another area where it had previously taken 30 seconds or more.
The display seems smoother and doesn't jump so much for one screen to the next.
Finally it seems to calculate the routes quicker and when i had to take a diversion it seemed to calculate the new route quicker.
Or just me?
PaulB2005
PostPosted: Sat Apr 08, 2006 1:00 pm    Post subject: Reply with quote
Me too.
Just discovered - no more spaces in postcodes!!! Yay!!
When selecting a country it jumps to the spell list and not the country list so you have to back arrow out to select your country. No major hardship.
PowerLee
PostPosted: Sat Apr 08, 2006 1:30 pm    Post subject: Reply with quote
Just upgraded my I3 to firmware 2.9 Smile
It looks like Garmin really look after there customers too with these web updates :D
Lester_Burnham
PostPosted: Sat Apr 08, 2006 2:42 pm    Post subject: Reply with quote
Or just me?
Were you using the beta before 2.90?
Or are you comparing it to 2.70?
With computer software, at least, it's often observable that betas can be a fair bit slower than gold code, on account of all the error trapping and debugging code that's normally in betas.
I suppose if it was 2.82 that was a fair bit slower for you, that would explain it.
If it was 2.7 that you're comparing with, well I guess they've just upped their game ;-)
Page 2 of 14
23.013 (15 Jan 25)
