brianpp Occasional Visitor
Posted: Tue Apr 04, 2006 9:51 pm Post subject: hgv on tiny roads |
hi
using tt nav 5 with ipaq rav 1710.
bieng a hgv driver wondered if thiers any way to select only motorways & A roads, as it sends me down some very small roads |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Tue Apr 04, 2006 10:15 pm Post subject: |
Always select 'Quickest Route', but even then it's not guaranteed to avoid small roads. _________________ Richard
Ginger Lifetime Member
Joined: 02/07/2003 18:39:46 Posts: 38 Location: Warrington UK
Posted: Fri Apr 07, 2006 2:38 pm Post subject: |
Sorry to disagree Oldboy, but i find that when using limited speed set to 54 TT keeps me on main roads until the last moment. It will even go around an area and come in from the other side if that keeps you on a motorway longer. I know that this doesn't sound logical but it just seems to work. _________________ Alan |
Posted: Fri Apr 07, 2006 8:25 pm Post subject: |
Ginger wrote: | I know that this doesn't sound logical but it just seems to work. |
I have to say that my observations were done nearly a year ago.
I've just done some routing tests and in only 1 out of 12 did the Fastest and the Limited (54) differ in their Routing. Then the only difference was that one took a Left and the other a Right, to end at the other side of the 'square'. ![Confused](modules/Forums/images/smiles/icon_confused.gif) _________________ Richard
alix776 Pocket GPS Moderator
![](modules/Forums/images/avatars/6212487444319be6786243.jpg)
Posted: Fri Apr 07, 2006 8:35 pm Post subject: |
limited speed at 54 is the best setting to use for an hgv but even then it can throw a curve ball now and again shortest will use the smallest roads to get you to your destination and fastest will tend to use the faster roads , limited speed seems to take a combination of these and give a very similar route to the truk settings on the garmin i3 _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Paul-in-Cornwall Occasional Visitor
Joined: Oct 02, 2005 Posts: 17 Location: Hertfordshire
Posted: Mon Apr 10, 2006 12:17 am Post subject: |
Oldboy wrote: |
I've just done some routing tests and in only 1 out of 12 did the Fastest and the Limited (54) differ in their Routing. Then the only difference was that one took a Left and the other a Right, to end at the other side of the 'square'. ![Confused](modules/Forums/images/smiles/icon_confused.gif) |
Which is why I posted a query like this some weeks ago , I found a possible way to avoid those little roads on a route or though I haven't fully tested if it will work every time, and that is to use fastest route, then use the 'avoid part of route' repeatedly under 'find alternative' button and avoid the roads with names in the middle of the list each time so you just have 'A' & maybe some 'B' roads left, it's a long way round of doing things but it worked on the last couple of journeys I did, didn't use a small road until really necessary, pity TTN5 doesn't have a user option route, one you can set which roads you most prefer to use.
paul |
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Mon Apr 10, 2006 11:46 am Post subject: |
It did have that option, then TomTom decided we really didn't need that and removed it. |
7andy Regular Visitor
Posted: Tue Apr 11, 2006 10:25 am Post subject: |
InfoMap Pocket Navigator 6 has a 'Truck' setting which I intend to try out when I'm towing the caravan. I've no idea if it works yet tho'! |
Posted: Tue Apr 11, 2006 1:20 pm Post subject: |
at the moment on infomap navigator the truck settings don't work but should do later _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
