If it's available and more accurate, why not use it?
Precisely. I cannot see the sense in anyone deliberately degrading the accuracy of their GPS device!
Deliberately degrading is something of an exaggeration.
EGNOS has only recently been available - before that, people were still using sat navs perfectly acceptably.
Using normal reception, you probably get reasonably good accuracy - certainly good enough for road / traffic use, and especially given the i3 tends to snap you to the road given a reasonable proximity.
The scenario MaFt gave, suggests more about a blip in reception - given the distances suggested - and that using EGNOS will likely be acquiring differently, rather than any improved accuracy in position, per se.
Aitch2 wrote:
I have never personally experienced any 'poor' routing with it enabled.
Aitch
And conversely, I have never personally experienced any 'poor' position, or directions on normal reception.
None of this is conclusive, or suggests that there's a warm happy setting that everybody should set out of preference.
As a generalism, the accuracy provided by EGNOS, will largely be irrelevant for driving on roads - go look at the specs for accuracy of the i3 with normal and with WAAS / EGNOS enabled.
To be honest from a logical point of view it seems odd that your choice of GPS mode has any relevance on the route at all. Surely the GPS reception just feeds the routing algorithm with the information that you are now at point X? After all you can calculate a simulated route without any GPS signal...so what happens then?
To receive different results i'm guessing there would have to be:
1) Separate routing algorithms for each type of GPS mode
2) A bug in the WAAS\EGNOS interpretation software that is somehow affecting the routing algorithm
Joined: Jan 22, 2006 Posts: 226 Location: South Coast, UK
Posted: Thu Apr 06, 2006 12:55 pm Post subject:
Not really. Unit accuracy on Normal setting cannot exceed that obtained using WAAS, and can be worse by up to a factor of 3. How else would you describe it?
Odd - I'd agree with, but nevertheless, it can and has.
I suspect that none of us, here, knows the answer to that.
But in much the same way that simulating a route from the same point, to actually getting the i3 to calculate the route in GPS mode has produced differing results for me - which is one of the main reasons I raised the inconsistent routing thing a while back - presumably the effects of different reception, or perhaps different satellites may (who knows for sure, here?) have some impact on routing.
Regardless, it definitely did have an effect. I stopped, got cancelled the route, got it to recalculate again, with the same odd route, cancelled that, switched to normal mode, got it to recalculate again, and hey presto - a more sane route.
You, I and everybody else here can only speculate as to why, without knowing an awful lot more about the internals of the i3.
I'm not seeing the logic behind that - surely it's equally possible there may be different parameters supplied, or different parameters affecting the calculation.
Or perhaps different satellites and reception pattern.
Who knows.
We can postulate on why, but that's all it'll likely ever be, the fact remains that it DID for me.
It's an exaggeration, because normal GPS reception is accurate enough for automotive use - as it has been for years.
You're probaly going to experience from teens of feet, to maybe 20-30 feet accuracy using normal gps reception.
Likely, using EGNOS, below 10.
When you think about the size of vehicles, their speed, the size of roads, lanes, and carriageways, it's hard to see the significance of such accuracy.
That's the thing - it is odd! I'm not doubting your experiences as there seems to be at least a few people here with similar problems.
True, but you never know though if someone will know andl be able to say that perhaps due to the extra inputs from WAAS/EGNOS then a different calculation is required. Or whatever the reason might be...
That would work too. My 2 points were ones that I just thought up off the top of my head. The amount of possible reasons is probably many.
I guess the only thing that can be done is to report it to Garmin and highlight times (and the locations) where this has happened so that (if they wish) they can test the reasons behind this or perhaps offer an explanation. Perhaps if people who have had this problem report it to Garmin we may see it fixed or a reason why an inconsistency may exist?
planned a route to exit at j11 on the a/c/w m60 (manchester) last night to a destination .3 mls off the motorway.
chose this as the slip road is some 600 yds long and follows the exact path of the main carriageway until it drops below its level at the roundabout. all that seperates the two is the barrier.
gps normal failed to notice i had taken the exit as requested and recalculated a 2 mile diversion via the next exit.
waas/ egnos noted the correct actions and i arrived at destination without diversion.
another victory for WAAS/EGNOS in an ever complicated world.
Funnily enough, that's a very similar scenario that I used to see whether it would make any difference.
Longish sliproad off a motorway, that largely runs parallel for quite a while, and separated from the motorway by a barrier.
It slowly, tapers away from the motorway, and leads to a largish rounadbout under this motorway.
Now using either normal reception, or using EGNOS, it doesn't detect when I've done either - ie stay on the motorway, ignoring the route to leave it, or conversely, leave the motorway when it's directing me to stay on.
In either scenario, it only really understands that I've deviated from the route (in either normal GPS mode, or EGNOS) when I'm either just on, or just over the roundabout.
What I find odd about your first example, being that the i3 appears you to snap you to the current route and road, if you're within a certain proximity to the road - which (I suspect) is why in my scenario, the mode had no effect - it assumed I was on the correct road, whether using either normal or EGNOS.
