Pocket GPS World :: View topic - BT Driver update
BT Driver update
neilsum
PostPosted: Thu Nov 06, 2003 5:38 pm    Post subject: BT Driver update Reply with quote
Brighthand have a link to an HP (US based) driver update.
Looks like it fixes the hang when switching off the ipaq while there is an active BT connection.
Will it work Ok on UK based ipaqs?
http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/locate/105_5722.html
-Neil
lbendlin
PostPosted: Sat Nov 08, 2003 4:46 pm    Post subject: Reply with quote
Why don't you try it out and let us know? You can always roll back if necessary (of course you should do a full backup before starting the test)
Lutz
TomTom/TeleAtlas NAVTEQ
neilsum
PostPosted: Mon Nov 10, 2003 1:52 pm    Post subject: Reply with quote
Ok,
Bin there, done that and it works fine.
In TT2 while running with BT GPS link I just switched off my IPAQ then switched it back on. TT2 took a bit of time to start updating the map again but it all came back to life and carried on as normal after about a minute.
:D
-Neil
TTN2
PostPosted: Mon Nov 10, 2003 1:58 pm    Post subject: Reply with quote
I tried this on both the 1940 and 2210, it does stop the bluetooth manager when you start TomTom and press cancel without selecting a Bluetooth Device, but when you exit the application it is still at the background giving the Bluetooth Browser endlessly and need to soft reset both the devices before loosing it.
My Advise: modify the registry with an reg editor and remove the autostart in the Bluetooth software, this is the best solution yet.
22.055 (29 May 24)
