Pocket GPS World :: View topic - Maps not available
Maps not available
newman
PostPosted: Tue Apr 04, 2006 11:44 pm    Post subject: Maps not available Reply with quote
Hi all was working fine with navman 520 until i installed the speed cameras, i did everything right followed all the instructions the cameras are showing on the icn only problem is when you tap maps or go to it comes up with a message no maps available helllllllp please they are on the icn why has it stopped working??????? Also it refused to turn off i have had to leave it on for the battery to go flat.. Crying or Very sad
Daytona
PostPosted: Wed Apr 05, 2006 10:20 am    Post subject: Reply with quote
Not sure what you done regarding the speed cameras but there is a master off switch on the back. Did that not work?
Maybe worth trying a reinstall of the maps and giving it another go.
Gee-Pee
PostPosted: Wed Apr 05, 2006 11:11 am    Post subject: Reply with quote
Those are good suggestions Idea Try a soft reset also - that may reinstall the maps.
This has happened to me a couple of times after updating my POIs. I suspect it could be something to do with the fact that it is impossible (?) to 'STOP' the device on computers and that pulling the plug is the only way to disconnect it. Try switching off the battery on the back of the device, then removing the SD card. Now switch on again and then re-insert the card. Usually worked for me. Also getting a fix seems to restore the status quo. Wink
Gee-Pee
Lifetime member PGPSW - time rapidly decreasing
Ian_S
PostPosted: Wed Apr 05, 2006 1:47 pm    Post subject: Reply with quote
I had the same problem on Monday morning, after installing some POI files on Sunday.
Resetting with the stylus didn't fix it in my case, however the following did work:
1) Go to Preferences / Maps / Memory Card (nb might be storage card, haven't got ICN in front of me and trying to remember!)
2) Deselect all the maps and Save
3) Re-select them all and Save again
4) The ICN now reloaded all the maps and everything worked fine - for me anyway!
HTH
Ian
22.063 (19 Jun 24)
