Pocket GPS World :: View topic - TomTom One Car Charging Lead
PostPosted: Tue Apr 04, 2006 8:30 am    Post subject: TomTom One Car Charging Lead Reply with quote
I have the TT1 and I am finding the car charging lead untidy.
I note that some other manufacturers supply a coiled lead that looks far more tidy. This would prevent passengers catching the lead by accident as mine trails into the passengers footwell. I have tried using a rubber band to shorten the lead but that looks untidy also.
Does anyone know whether another manufacturers lead would work with the TT1 ?
PostPosted: Tue Apr 04, 2006 11:23 am    Post subject: Reply with quote
BEWARE!!!!!
Hopefully you are aware of this already, but the TomTom cable is NOT just a lead, but an in-line power supply.
All the curly cables I've seen are just that - cables.
You would need to find one that includes the required 12 Volt to 5 Volt converter in the plug, otherwise....BANG!
TonyHoyle
PostPosted: Tue Apr 04, 2006 2:24 pm    Post subject: Reply with quote
Or just snip the power supply off the end and insert the new cable.
I just wish there was one available that you could wire in more permanently.. having all those cables around is quite untidy.
PostPosted: Tue Apr 04, 2006 4:39 pm    Post subject: Reply with quote
Lots of people have solved this by installing a new cigarette lighter socket behind the dash, losing the adapter and any spare cable behind there too, and running the cable up through a small hole behind the mount.
Or under the mount like I did....
PostPosted: Tue Apr 04, 2006 5:24 pm    Post subject: Reply with quote
Just a quick word of caution when messing around behind the dashboard of a modern car, if its fitted with airbags be extra careful if disconnecting wiring, or joining wiring to an existing circuit, make a mistake and you could end up with a very loud BANG and a costly repair bill, bear in mind these devices can case serious injury (the airbag that is not the TomTom) if they go off inadvertantly - Mike
PostPosted: Tue Apr 04, 2006 5:42 pm    Post subject: Reply with quote
Good point. Always arm yourself with the wiring diagrams if it looks at all complex, so you can work out the best circuit to tap into. (I got a full workshop manual on CD from e-bay.... oh oh probably on dodgy ground there Embarassed )
PostPosted: Wed Apr 05, 2006 8:02 am    Post subject: Reply with quote
Thanks for the replies.
I have no intention of using a 'compatible lead' unless I know it would work.
Alternative routing looks like a viable solution.
