Kremmen Pocket GPS Verifier
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Tue Apr 04, 2006 8:30 am Post subject: TomTom One Car Charging Lead |
I have the TT1 and I am finding the car charging lead untidy.
I note that some other manufacturers supply a coiled lead that looks far more tidy. This would prevent passengers catching the lead by accident as mine trails into the passengers footwell. I have tried using a rubber band to shorten the lead but that looks untidy also.
Does anyone know whether another manufacturers lead would work with the TT1 ? |
Andy_P Pocket GPS Moderator
Posted: Tue Apr 04, 2006 11:23 am Post subject: |
BEWARE!!!!!
Hopefully you are aware of this already, but the TomTom cable is NOT just a lead, but an in-line power supply.
All the curly cables I've seen are just that - cables.
You would need to find one that includes the required 12 Volt to 5 Volt converter in the plug, otherwise....BANG! |
TonyHoyle Regular Visitor
Posted: Tue Apr 04, 2006 2:24 pm Post subject: |
Or just snip the power supply off the end and insert the new cable.
I just wish there was one available that you could wire in more permanently.. having all those cables around is quite untidy. |
Posted: Tue Apr 04, 2006 4:39 pm Post subject: |
Lots of people have solved this by installing a new cigarette lighter socket behind the dash, losing the adapter and any spare cable behind there too, and running the cable up through a small hole behind the mount.
Or under the mount like I did....
![](http://homepage.ntlworld.com/andy.pearce2002/TomTom/Mount/IMG_2951(Small).JPG) |
Posted: Tue Apr 04, 2006 5:24 pm Post subject: |
Just a quick word of caution when messing around behind the dashboard of a modern car, if its fitted with airbags be extra careful if disconnecting wiring, or joining wiring to an existing circuit, make a mistake and you could end up with a very loud BANG and a costly repair bill, bear in mind these devices can case serious injury (the airbag that is not the TomTom) if they go off inadvertantly - Mike |
Posted: Tue Apr 04, 2006 5:42 pm Post subject: |
Good point. Always arm yourself with the wiring diagrams if it looks at all complex, so you can work out the best circuit to tap into. (I got a full workshop manual on CD from e-bay.... oh oh probably on dodgy ground there ) |
Posted: Wed Apr 05, 2006 8:02 am Post subject: |
Thanks for the replies.
I have no intention of using a 'compatible lead' unless I know it would work.
Alternative routing looks like a viable solution. |
