Pocket GPS World :: View topic - TT One Map on TTG
TT One Map on TTG
Blinkey
PostPosted: Mon Apr 03, 2006 6:35 pm    Post subject: TT One Map on TTG Reply with quote
I have a TT Go and have just 'borrowed' the spanish map data from my Dads TT One card. I put his sd card in my TTG and it all booted up to the map screen but obviously said "No GPS located" I have now copied the data to use when I go over there next week. Does anyone know if it will work when I get there? It all looks good so far Rolling Eyes
Any help gratefully appreciated :D
Blinkey Driving
rugrat2
PostPosted: Mon Apr 03, 2006 6:54 pm    Post subject: Reply with quote
Dont you have to have an activation code?
Blinkey
PostPosted: Tue Apr 04, 2006 1:39 pm    Post subject: Reply with quote
I don't know. The map was the original one that came with my Dads TT One. It seems like it will work and I am assuming the "No GPS Located" is because I turned it on in the UK not Spain, so it had no UK map data to tell it where it was. And when I turn it on in Spain it will be fine, I hope 8O
Blinkey
adamf
PostPosted: Wed Apr 05, 2006 12:12 am    Post subject: Reply with quote
if it asks for a code use the ttone code so make a note of it before you go Wink you may be better using just the map eg put the spain map on your card not all the other files...
Blinkey
PostPosted: Fri Apr 07, 2006 7:17 pm    Post subject: Reply with quote
Would it not be ok to put both UK and Spain maps on one card? If so which files do I need to put on my UK card from the spanish directory? I have the spain maps in a directory on my pc not a card so ideally i would like both maps on the same card if it is 'dooable'??
Many thanks for any help.
Blinkey 8O
PostPosted: Fri Apr 07, 2006 8:49 pm    Post subject: Reply with quote
Each country has it's own Map Folder so you will have to Copy the entire contents of the Spanish Map Folder to it's own Folder on the SD Card.
Blinkey
PostPosted: Sat Apr 22, 2006 3:32 pm    Post subject: Reply with quote
Hey ya
Just come back from Spain and it all worked a treat. Now I have loads of favourites programmed for the next trip!!
Many thanks for all your help :D
Blinkey 8O
22.063 (19 Jun 24)
