GaryL Regular Visitor
Posted: Sun Apr 02, 2006 8:54 pm Post subject: TT Mobile 5 - Voices |
Does anyone know a cure for this :
When navigating any download voice is unable to give directions clearly.
all instructions are in broken speach, but if you were to use the test function when changing a voice the direction are perfectly clear.
The error seam to have occured since i purchased an upgraded map a few days ago.
Thanks in advance if anyone knows a fix. |
Posted: Sun Apr 02, 2006 10:21 pm Post subject: |
Gary, were the voices you "downloaded" actually intended for the device you are using, the voice files for PPC are constructed at a different sampling rate than those intended for a mobile "smart phone" device - just a thought - Mike |
Posted: Mon Apr 03, 2006 12:24 am Post subject: |
I selected the voices from Ray's Website and download the john clease voice from tomtom i was assuming the tommtom one would be at the right rate.
I have also now removed all the POI's except the speed cameras, after reading that it could be the pois that are causing a problem, will wait untill tommorow to test.
Thanks for responding. |
Posted: Mon Apr 03, 2006 7:52 am Post subject: |
Gary, you need to disable ALL the POI then configure the cameras to appear using "Warn when near POI" its in Change Preferences/ Manage POI, As you are using Rays voices why not try one of the custom voice warning files as well to go with the nav voice, the Liz set-up if very impressive on the PDA, not heard it yet on a phone though - Mike |
Posted: Tue Apr 04, 2006 12:36 am Post subject: |
Thanks for the reply have made the required changes.
Now just need to work out how to make my own data.chk file that actully works on the 6680..
I have tried various methods but now seam to allow me to change one of the warning to one i would to use for say informing me that i am near an LPG petrol station. |
