Pocket GPS World :: View topic - Arkon mount with loudspeaker?
Rich
PostPosted: Sun Nov 02, 2003 11:24 am    Post subject: Arkon mount with loudspeaker? Reply with quote
Hi Dave and all.
By any chance anyone have tested the arkon mount with loudspeaker? spotlight sells one. I got a smart and a ford focus. Just worry I can't quite hear the instruction when I am in the smart (a bit of road noise. not too bad). Going to get hp2210, tomtom2 and a receiver (not yet decided).
(I think the mount will charge the pocket pc too.
Any opinions or experience welcome.
Thanks,
Rich
PostPosted: Sun Nov 02, 2003 12:31 pm    Post subject: Reply with quote
Hi Rich,
Check out our review of the Seidio Mount at http://www.pocketgpsworld.com/seidiomount.php
Seidio make the mount for Arkon, so they are virtually identical.
longwori
PostPosted: Mon Nov 03, 2003 12:18 pm    Post subject: Reply with quote
I have the Arkon CM506 mount (if I remember the number correctly!). It works well, sounds great with the speaker in my soft-top and will recharge the 2210. Note that to charge the 2210 it uses the sync port in the botom of the 2210 so unless you buy a splitter from PC-Mobile or somewhere, you wont be able to plug your GPS in at the same time. (no problem if you are going for a bluetooth or Compact Flash GPS though). This would also be a problem with the Siedio mount too.
The cheapest place I found for my mount was 121.eurotech.co.uk - they showed a stock level of zero but when I phoned this was incorrect and it arrived in a couple of days (no postal strikes then!!).
Good luck.
Rich
PostPosted: Mon Nov 03, 2003 10:25 pm    Post subject: Reply with quote
the website doesn't seem to work. can't find product..... Crying or Very sad
PostPosted: Mon Nov 03, 2003 10:57 pm    Post subject: Reply with quote
121 Eurotech and the associated a2 Distribution in Guildford, Surrey allegedly went into receivership mid October.
In view of this and unless you can satisfy yourself that this is not the case or that any orders placed will be honoured then I would advise you place your order elsewhere.
Rich
PostPosted: Tue Nov 04, 2003 8:44 am    Post subject: Reply with quote
Hi all.
I wonder if the output (6v ?) from this mount can correctly charge hp2210 (also 6v??) ?
If I am going to use tomtom and hp2210, will it be loud enough at all?
Thanks,
Rich
Need feng shui consultation?
try www.chiwing.co.nr
22.063 (19 Jun 24)
