Pocket GPS World :: View topic - Program memory low - recurring
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
phinea
PostPosted: Wed Mar 29, 2006 11:11 am    Post subject: Program memory low - recurring Reply with quote
I'm running TTN5 on an iPAQ 2210 with 1GB CF card.
TTN5 regularly crashes with a PDA generated message "Program memory low!" and I have then to perform a reset (difficult when driving!).
I have moved TTN5 to the CF card and removed it from main memory (I think I managed to achieve this - don't know exactly how to check). The only other app that I have running in the background is Pocket Breeze (calendar app).
What do I need to do to stop this happening?
Also, I notice that 3 times out of 4 the PDA clock goes awry and has to be reset after a soft reset. This has only started happening recently - any suggestions?
lbendlin
PostPosted: Thu Mar 30, 2006 6:41 pm    Post subject: Reply with quote
can you afford a hard reset and a manual re-install of only the applications you really need? That's the only way to rule out any other memory leaks. TTN itself should not leak that heavily.
Lutz
TomTom/TeleAtlas NAVTEQ
alix776
PostPosted: Thu Mar 30, 2006 6:54 pm    Post subject: Reply with quote
if your useing a bt gps have you got the most up to date rom image on the device there is a bluetooth security update might e worth a try
device Lumia 950 xl
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
