Pocket GPS World :: View topic - GR-213 TTFF
GR-213 TTFF
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
omaruk
PostPosted: Wed Feb 01, 2006 7:53 pm    Post subject: Reply with quote
I too would like to extend my thanks to Julie, my 2 replacement units arrived today, just 1 days turnaround thankyou. I too will now test my units like Johnmar. Thanks again
Omar
MikeProcter
PostPosted: Wed Feb 01, 2006 10:32 pm    Post subject: Reply with quote
I'm really impressed with mine, if I have switched it on once during the day, then it gets a fix within seconds next time I switch it on, even hours later. I now only power it via the cigarette lighter socket when I want it on. I have be running mine for two weeks or so now & covered over 1000 miles. I'm sure that it is more sensitive than the previous one- much better reception.
Skoda Columbus and for emergencies: TomTom + iPhone 4 & TomTom car kit
MikeProcter
PostPosted: Wed Feb 01, 2006 10:33 pm    Post subject: Reply with quote
When are we going to get the promised reveiw. (make sure its a new verion!)
Mike
omaruk
PostPosted: Tue Feb 14, 2006 12:37 pm    Post subject: Reply with quote
So far the new version has been behaving impeccably for over 2 weeks now with very fast TTFs. Happy bunny once again
MikeProcter
PostPosted: Tue Feb 14, 2006 12:57 pm    Post subject: Reply with quote
Julie & Holux have definitely come up trumps for us. The unit is amazing all the time, even more sensitive than before. Thumbs Up
Soepy
PostPosted: Wed Feb 15, 2006 8:28 am    Post subject: Reply with quote
I've just received my GR-213 and noticed that it has firmware 213-53800337, which is less than the 54900001 mentioned in the post from JM-HoluxUK. Should I be worried?
Furthermore, I live in Romania and there's no chance to get the unit replaced or flashed here Sad Is there any way I can flash the unit myself? I've read some posts on another forum and it seems I need SirfFlash and the right firmware file; that's it?
Thanks,
S.
johnmar
PostPosted: Wed Feb 15, 2006 7:49 pm    Post subject: Reply with quote
Hi Soepy
When I got my replacement GR-213 directly from Julie (JM-HoluxUK) a few weeks ago, she put in a note to say that the Serial Numbers ( the number you quoted is not firmware) for the upgraded receivers are lower than the problem units. Apparently Holux TW had a problem with their numbering.
Sorry I don't have the actual numbers which she quoted, but you can always contact Holux UK to confirm.
Bottom line, if the unit is the old type and is deffective, a firmware flash will not fix the problem. The new units have revised hardware.
After a wek to 10 days you wil know whether or not you have the revised receiver. They really are very good.
Regards
John
iPAQ3830 (32MB) PPC2002 ROM 1.20
CF Expansion Pack
Holux GR-213 GPS Mouse (GSW3.1.1 -3.1.00.07 C23B1.00)
Kingston Elite Pro 1 GB CF Card for maps
Viking 512MB SD Card (not used for navigating)
TTNav 5.210 (5430) Maps of W Europe
Soepy
PostPosted: Fri Feb 17, 2006 2:40 pm    Post subject: Reply with quote
Thanks for the reply. I guess I shouldn't assume for the moment that the unit is broken. I'm still waiting for the car to go with the GPS Wink
S.
uffe73
PostPosted: Tue Mar 28, 2006 2:52 pm    Post subject: Reply with quote
johnmar wrote:
I have now received my replacement receiver from Holux UK. Very good service, thanks Julie, it was sent out the same day that my original (1st replacement) was received .
I have only had a chance to briefly try-out and it seems fine. However, all was initially fine for the two previous units as well. I fully intend to leave the cig power adapter permanently connected as I assume that the new hardware will now cope with the power fluctuations caused on engine cranking. The proof of the pudding....etc.
All being well, this thread should soon be redundant Wink
John,
I haven't followed this forum for a while so I missed the information about the HW update. That's really interesting. I just spoke to my dealer, who previously refused to repay me my money. Now, for some reason, it wasn't a problem and I would get my money back. I wonder if Holux have gone out to all dealer and confirmed the previous problem...
So, the question is if I should go buy one of the "new" GR-213 and hope that it actually works or rather go for another receiver. Is your latest replacement receiver still working fine when you leave it permanently in the cig socket?
If I buy a new GR-213, do you know what serial number I need to get to know it's got the new HW?
Ulf
PS: Really good information sharing in this thread!
uffe73
PostPosted: Tue Mar 28, 2006 5:04 pm    Post subject: Reply with quote
I just realised that this information hade already been mentioned in the thread. So, I should be looking for a unit with a s/n higher than 213-54900001.
Rgds,
Ulf
PS: I'm still keen on knowing if this new hardware is still working flawlessly
JM-HoluxUK
PostPosted: Tue Mar 28, 2006 9:40 pm    Post subject: Reply with quote
Hi Ulf,
I hope that John or Mike will come back with some "user" feedback for you, but from my point off view it looks like the new hardware has done the trick.
Julie
johnmar
PostPosted: Wed Mar 29, 2006 3:15 pm    Post subject: Reply with quote
Hi Ulf
I'm delighted to confirm that my replacement unit continues to work very well.
Yes it is left permanently connected to the cig socket, and usualy provides a fix in under one minute. As previously mentioned I use TTN5 and only launch this once I have a fix.
BE CAREFUL about serial numbers as I believe that the 'new batch' (at least the unit supplied to me) had lower numbers than the problem units. Julie can supply accurate information. Apparently there was a problem at the TW factory in assigning S/N's.
Regards
John
CF Expansion Pack
uffe73
PostPosted: Thu Mar 30, 2006 7:02 pm    Post subject: Reply with quote
Julie,
Can you give any comments to John's remarks regarding serial numbers?
Could you also please tell me if a receiver with s/n above 213-60401280 is safe to buy, with regards to the HW upgrade?
Another question: Are the latest GR-213 receivers using the 1st or 2nd generation of Sirf III ?
Best regards,
Ulf
TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
TT RDS-TMC: 4V00.013
Maps: Scandinavia v840.2562, Western_Europe v715.1703
Garmin GPSMap 60CSx (SW ver. 3.70)
JM-HoluxUK
PostPosted: Thu Mar 30, 2006 11:30 pm    Post subject: Reply with quote
Hi Ulf,
Anything with a serial number over 213-54500001 purchased from a Holux UK retailer will have the latest firmware in.
I've had a batch from TW starting 60401*** with the last 3 digits higher & lower than that stated which definately have the hardware upgrade so you should be safe with this device.
Julie
MikeProcter
PostPosted: Wed Apr 12, 2006 10:39 am    Post subject: Reply with quote
More feedback....I have been using this for nearly 4 months now.
What can be said? it now has a very fast TTFF every single time - less than a minute, and if it has been left for a short while - 1-2 hours it is even faster, just a few seconds. I have mine now permanently fixed in the car, with the receiver on the dashboard out of general sight, and it is only powered up when the ignition is switched on. What more could I ask for?
Now I just need a GR236 for when I'm on the bicycle or walking, as my Tom Tom Mk1 BT receiver can't cope when used for walking!
Page 8 of 9
22.123 (18 Dec 24)
