Pocket GPS World :: View topic - post code search stopped working
worthingsaxovtr
PostPosted: Mon Mar 27, 2006 4:17 pm    Post subject: post code search stopped working Reply with quote
i have a tomtom go 300
with update 5.44
and map version v635 downloaded form the tomtom site, and installed using the windows installer
try to go to a meeting today for work and ended up being two hours late, i cant pub the full post code in
for example rg12 5sg, would only be rg12
and if their are more than one road with the same name i end up being late,
tried it on other addresses and it will only taje the first 3 digits of a post code
cheers
nigel
worthingsaxovtr
PostPosted: Mon Mar 27, 2006 5:45 pm    Post subject: Reply with quote
after reading one of the other threads,
i have tapped navigate and then to postcode, and this does nto work either, i tap in the postcode, but then it just sist there doesnt give me any more options, if i tap done it presents me with a random orad,
if i type in the postcode then the street, there is no space option and again it doesnt find anything
please help its driving me mad,
and i need this for work, should have stayed with the old maps and software
cheers
nigel
PostPosted: Mon Mar 27, 2006 7:22 pm    Post subject: Reply with quote
You should have a Folder in the Root of the SD Card called Zip. This contains the Great_Britain.Postal File that contains the Postcodes.
Is there a possibility you have deleted the Folder?
Do you have a previous Full Backup of the 300? This would have the Zip Folder.
I don't know if the new download contains the Postcode File, as I have never bothered to Upgrade that way.
Tumbleweed
PostPosted: Mon Mar 27, 2006 7:41 pm    Post subject: Reply with quote
cheers
nigel
Does navigating to an address work?
worthingsaxovtr
PostPosted: Mon Mar 27, 2006 7:42 pm    Post subject: Reply with quote
just had a look and yep it is there
worthingsaxovtr
PostPosted: Mon Mar 27, 2006 7:44 pm    Post subject: Reply with quote
say for exmaple i tapped in the first part of an address say rg1 for reading
then i could only tap in the road, and not the rest of the post code
which is not a very good solution as there could be more than one road called the same thing, but in a different sub zone of for example rg1
worthingsaxovtr
do i have to activate this postal file, or move it elsewhere
PostPosted: Mon Mar 27, 2006 7:50 pm    Post subject: Reply with quote
You don't have to activate the Postcode File.
You are sure the Folder is in the Root of the SD Card? Try a reset to force TT to re-read the SD Card, and see if that helps.
worthingsaxovtr
PostPosted: Mon Mar 27, 2006 7:59 pm    Post subject: Reply with quote
the file is sitting in a folder called zip
this folder is sitting on the tomtom next to the other folder called
great_britian_plus
licenses
when you say root,
is there a folder called root then
as at the moment it seems to be just amongst a collection of files and folders
MELennium
PostPosted: Mon Mar 27, 2006 8:04 pm    Post subject: Reply with quote
Hi worthingsaxovtr
What size is your postcode folder, I have the TomTom One & mine shows 13.0mb, just wondered if maybe yours was possibly corrupt?
TomTom Go 910 (3) v.6.522 Map Western Europe v.650 with useless TMC receiver
Ex. owner TomTom 910 (2) Returned Faulty
Ex. owner TomTom 910 (1) Returned Faulty
Ex. owner TomTom One v.5.420 Map UK v.605
Ex. owner Garmin i3 v.2.7 Map UK V.7
PostPosted: Mon Mar 27, 2006 8:05 pm    Post subject: Reply with quote
That sounds right.
The Root is the level at which you can see the Drive letter, TomTom (ESmile, in Explorer.
Have you tried a Reset?
worthingsaxovtr
PostPosted: Mon Mar 27, 2006 8:07 pm    Post subject: Reply with quote
9.8mb file size
PostPosted: Mon Mar 27, 2006 8:09 pm    Post subject: Reply with quote
9.8MB is right.
worthingsaxovtr
PostPosted: Mon Mar 27, 2006 8:10 pm    Post subject: Reply with quote
tried a reset and it still wont let me input a full spot code, like it used to
only the first 3 characters
MELennium
PostPosted: Mon Mar 27, 2006 8:30 pm    Post subject: Reply with quote
with update 5.44
Did you upgrade your firmware when you installed your new maps? or was it working ok with this firmware (5.44) & your old maps?
22.064 (26 Jun 24)
