Pocket GPS World :: View topic - what ac adaptors can i use with the one
notorious19
PostPosted: Fri Mar 24, 2006 8:11 pm    Post subject: what ac adaptors can i use with the one Reply with quote
after a cheap ac adaptor to use with the tom tom one what do i need to look out for so i know i can use it ? also cab anyone sugest a cheap one ?
Tumbleweed
PostPosted: Fri Mar 24, 2006 8:59 pm    Post subject: Re: what ac adaptors can i use with the one Reply with quote
The cheapest would be to just charge it in the car, what are you going to do with it that will take more than 2 hours?
Tw
spot
PostPosted: Fri Mar 24, 2006 11:56 pm    Post subject: Reply with quote
This one from argos works perfectly acceptably - just make sure you follow the instructions in the pack about polarity, and get the voltage setting right - all as embossed on the TT.
http://www.argos.co.uk/static/Product/partNumber/9828915.htm
It is useful to have a home charger if you want to change settings to the TT at home, only to find that the battery is flat, as I did this afternoon!
Good luck. :D
Spot
steveJ
PostPosted: Sat Mar 25, 2006 11:20 am    Post subject: Reply with quote
As Spot says above the Argos adaptor works fine, but if i'm just connecting to the PC for downloads / backups etc. I use this http://shop.game.net/ViewProduct.aspx?cat=11234&mid=326193. Works a treat :D
Steve
notorious19
PostPosted: Mon Mar 27, 2006 11:53 am    Post subject: Reply with quote
thanks guys, i want it so i can conect it to the comp to downloaad to the one,i have the cable to connect it to the comp but it says it needs to be powered when you do it so what should i get ?
PostPosted: Mon Mar 27, 2006 12:16 pm    Post subject: Reply with quote
If that's all you need it for, don't bother.
They say that in the manual because they want to avoid the unit shutting down half way through writing to the card.
So long as the Go/One is fully charged before you start, you will be fine.
spot
PostPosted: Mon Mar 27, 2006 12:23 pm    Post subject: Reply with quote
Notorious
Firstly the unit must be charged up (either plug in the car, or with an adapter) - if it's brand new you will need to leave for at least two hours to charge up internal batteries. You can then use it as a free standing module and connect to your computer with the supplied usb lead as per instruction book. If you want to edit the SD card without using the TTone you can buy a usb card reader from any computer shop and insert the card into the reader - I do this for upgrades and installing camera database updates from this site.
Most folks will advise you to buy a second (larger capacity SD card) and copy all of the original card data to the new card - thus not spoiling the original if it all goes wrong! There are plenty of instructions on this site as to how to do this.
Try to be a little more specific with your questions and we can surely help. Smile Good luck. Spot
notorious19
PostPosted: Mon Mar 27, 2006 2:40 pm    Post subject: Reply with quote
:D thanks for all your help
chrisbin
PostPosted: Mon Mar 27, 2006 3:09 pm    Post subject: Reply with quote
Spot
................anywhere exactly.....or scattered through the postings?? Re. my other post, I'm not having much success with this...
bobbyjo
PostPosted: Mon Mar 27, 2006 5:10 pm    Post subject: Reply with quote
Found a good one off ebay.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=9702332367&ssPageName=STRK:MEWN:IT
USB and power combo.
Matt
porndoguk
PostPosted: Mon Mar 27, 2006 5:59 pm    Post subject: Reply with quote
sony psp charger will work, and you can get a genuine one on ebay for £5 inc p&p,
spot
PostPosted: Mon Mar 27, 2006 8:09 pm    Post subject: Reply with quote
chrisbin
Please go to this thread and read Andys advice - im sure you have not copies all files as you thought - you need to copy HIDDEN files too. Switch to this thread if you still have problems.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=37636
I use a TTG 300, but I think the advice is still good for a One - if not other members will help out i'm sure.
Good luck Spot
chrisbin
PostPosted: Mon Mar 27, 2006 11:20 pm    Post subject: Reply with quote
Hi Spot
Sorry for thread drift....I was getting frustrated.... Embarassed Gonna try the recommendations tomorrow and report back (on the other thread... Wink )
Thanks!
23.061 (04 Jun 25)
