Pocket GPS World :: View topic - POI Distances
POI Distances
BOBBYBARLOW
PostPosted: Fri Mar 24, 2006 5:34 pm    Post subject: POI Distances Reply with quote
Hello There
I have downloaded LPG POI,s onto my 510 but they seem to be listed in alphabetical order rather than nearest distance.Any one any ideas
filgreen
PostPosted: Fri Mar 24, 2006 6:00 pm    Post subject: Reply with quote
The POIs after downloading are in alphabetical order in the spreadsheet, but if you follow the instructions, when they are loaded into the navman should appear in the correct geographical location as you drive. Don't forget to select the icon when installing them, it is in a seperate file.
Or are you referring to another problem?
Geoff_UK
PostPosted: Fri Mar 24, 2006 6:10 pm    Post subject: Reply with quote
BobbyBarlow,
You'll probably find that it only lists the first 50 as well when you view them on the 510??
Don't worry about this either as they will all be visable on the map as you drive - the 510/520 only seems able to show a limited number of poi entries. Rest assured they're all there !!!
Good luck
tomtom one v2 - 7.162
2Gb Toshiba SD card
UK and IE plus major roads of WE - v675.1409
22.094 (25 Sep 24)
