Pocket GPS World :: View topic - Quest 2 Reset Help
Quest 2 Reset Help
jonv
PostPosted: Wed Mar 22, 2006 11:21 am    Post subject: Quest 2 Reset Help Reply with quote
While loading POI's my quest 2 locked up. Now when switched on it doesn't get past the title screen. Pwr+in makes no difference. Computer wont see it on USB. Heeellllpppp!!! Please Sad
jonv
PostPosted: Thu Mar 23, 2006 9:08 am    Post subject: Reply with quote
Sad Does no one have any suggestions or is it skuppered? If so it seems abit flakey to fail so easily. Or is it a faulty unit? Crying or Very sad
Skippy
PostPosted: Thu Mar 23, 2006 9:55 am    Post subject: Reply with quote
Welcome
I don't think it's knackered, it probably just needs resetting. Have a look at Mr Elsinga's excellent web pages. This man is a Quest guru. 8)
http://www.elsinga.org/quest-first-aid.html
Good luck!
Gone fishing!
rdhw
PostPosted: Sat Mar 25, 2006 12:29 am    Post subject: Reply with quote
I have had exactly the same problem after having uploaded a large number of custom POIs to a Quest 2. The Quest 2 then crashes after displaying the startup screen so that one can neither use any keys nor do anything via USB. The Quest first-aid procedures on the Elsinga site did not cure the situation: the Quest still crashed after the startup screen. The Elsinga procedures do not clear the Custom POIs, so the problem is not fixed.
Here is the only way I found to recover use of the Quest 2.
1. Power off the Quest 2.
2. Whilst holding down the OK button, press POWER.
3. The Quest 2 should then boot up into a special diagnostics screen.
4. Ignore the diagnostics screen - the important thing is that the USB interface is now live and will stay so.
5. Use POILoader to upload a very small number of POIs. This will delete the previously uploaded POIs which were causing the crash.
Now the Quest 2 should boot up normally. Good luck!
22.094 (25 Sep 24)
