Pocket GPS World :: View topic - speed cameras
speed cameras
clewezy
PostPosted: Tue Mar 21, 2006 3:02 pm    Post subject: speed cameras Reply with quote
i have followed all the instructions on the screens to put speed cameras on my tom tom one but it wont work. Can n e body help please??????? Smile
MarkHewitt
PostPosted: Tue Mar 21, 2006 3:13 pm    Post subject: Reply with quote
Since everyone says "It doesn't work... help!" all the time, about a dozen threads every day.. You'll need to give more information as to why you can't follow the instructions and what's going wrong.
A mod will be along in a moment to give you a post with various links in it.
PostPosted: Tue Mar 21, 2006 4:31 pm    Post subject: Reply with quote
Thanks Mark. Yes, someone will be along to get you up and running when we have a little more information about your problem.
We'll get you there, don't worry Smile
Privateer
PostPosted: Tue Mar 21, 2006 4:39 pm    Post subject: Reply with quote
Hi clewezy,
Welcome to the forum! Thumbs Up
I believe that that’s my cue! ;)
There are some guides that should be read (in the following order):
Arrow The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
Arrow How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
Arrow How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
Once you have installed, set up, and used the PocketGPSWorld camera database for a while on your TomTom SatNav system. You may want to share and send in details of cameras yourself. You can do this by using the PocketGPSWorld POI Capture utility:
Arrow The PocketGPSWorld POI Capture utility.
You do not need the PocketGPSWorld POI Capture utility on your TomTom SatNav system in order to use the PocketGPSWorld camera database. However if you want to send in camera details then POI Capture makes the process of recording cameras much easier on TomTom Navigator and GO (original, 300, 500, and 700). At the moment POI Capture will not work with TomTom Rider, One, and mobile. This is for a technical reason, which we hope, will soon be rectified by TomTom.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Robert.
Garmin Camper 770 LMT-D
clewezy
PostPosted: Fri Mar 24, 2006 12:44 pm    Post subject: Reply with quote
do you have to have your tom tom one plugeed into the mains for you to download the speed cameras? according to the tom tom site, you have to. Confused Question
Privateer
PostPosted: Fri Mar 24, 2006 12:49 pm    Post subject: Reply with quote
Hi clewezy,
If you have a mains power charger then it's a good idea to plug it into your TomTom ONE every time that you connect the ONE to your PC.
However if you don't have a mains power charger then as long as your ONE is well charged then it will be OK.
Robert.
22.105 (30 Oct 24)
