wildey Occasional Visitor
Posted: Sun Mar 19, 2006 11:18 am Post subject: Garmin StreetPilot i3 has stopped talking to me..... |
Hi There,
I've had a streetpilot for 6 months, running v2.70 all working just fine.
Got half way home from a longish journey the other day with it powered from cig lighter and it just stopped talking to me. Just like that - no other factors !
Now it will occasionally mumble something unintelligible with lots of distortion.
Has anyone any experience of this or even any suggestions ?
Many Thanks,
Chris |
Lester_Burnham Frequent Visitor
Posted: Sun Mar 19, 2006 11:22 am Post subject: Re: Garmin StreetPilot i3 has stopped talking to me..... |
wildey wrote: | Hi There,
Many Thanks,
Chris |
Backup any favourites you want to keep using easygps (won't preserve the case of the name, will all be uppercase when you restore - and delete the built-ins (ie the Garmin locations) from the easygps backup - else you'll get duplicates when you restore).
Then try switching the audio / voice settings to American and then back to British.
If that doesn't make any difference, do a hard reset, and be prepared to restore any of your favourite locations, and POIs you've loaded.
If that doesn't cure it, I suspect you are looking at a true fault, and you'll need to contact either where you bought it from, or Garmin for support under warranty. |
Posted: Sun Mar 19, 2006 3:08 pm Post subject: How do I do a hard reset ? |
How do I perform a hard reset on the i3 please ?
Chris |
jeglet Occasional Visitor
Trajet Regular Visitor
Joined: Oct 04, 2005 Posts: 160 Location: Highlands of Scotland
Posted: Sun Mar 19, 2006 4:24 pm Post subject: |
Although you are using the 12v supply from your car, have you checked the 2 x 1.5v batteries are not flat. Sounds daft I know, but when my batteries go flat the unit doesn't always repond correctly until I put fresh ones in. |
zogman Frequent Visitor
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Sun Mar 19, 2006 4:48 pm Post subject: |
you dont need batteries in the i3 for it to work.... _________________ *************************** |
ps..when using a 12 volt supply.... _________________ *************************** |
Ash10 Pocket GPS Verifier
Posted: Sun Mar 19, 2006 6:11 pm Post subject: |
zogman wrote: | you dont need batteries in the i3 for it to work when using a 12 volt supply.... |
Quite a few people (myself included) have noticed that the i3 misbehaves when you're using the external power lead, and the batteries fitted in the unit are dead.
wildey wrote: | Got half way home from a longish journey the other day with it powered from cig lighter and it just stopped talking to me. Just like that - no other factors !
Now it will occasionally mumble something unintelligible with lots of distortion. |
Sounds familiar. I've had the audio die on two units now (albeit both within the first week) - one just became progressively more and more distorted, and the other became distorted before giving up completely.
Try what others have suggested above - namely resetting the i3, and reloading the language setting. If that doesn't work, I suspect that you're looking at a hardware fault. |
Posted: Sun Mar 19, 2006 7:33 pm Post subject: |
Ash10 wrote: | zogman wrote: | you dont need batteries in the i3 for it to work when using a 12 volt supply.... |
you and others must have been unlucky then..i've used my i3 (with v2.50 firmware ..if that makes a difference?) with new,flat and without batteries using the car power supply with no problems.... _________________ *************************** |
timber Frequent Visitor
Joined: Jan 18, 2006 Posts: 422 Location: Wild and Windy SW Scotland UK
Posted: Thu Mar 23, 2006 5:59 pm Post subject: Re: Garmin StreetPilot i3 has stopped talking to me..... |
Many Thanks,
Chris |
Chris,
can you post the outcome regarding your mute I3, I'm considering buying a Garmin c320 which is also exhibiting this fault, if its hardware I'll leave it well alone.
Derek. |
Posted: Thu Mar 23, 2006 10:35 pm Post subject: Mute machine...... |
Result was i spoke to Garmin who told me to send it in, they would reload the software and upgrade the maps for free at the same time and return it - all within 5 working days.
Their customer service was awesome.
Chris |
