Pocket GPS World :: View topic - hardwiring tom tom 300
ivanm
PostPosted: Sat Mar 18, 2006 10:10 pm    Post subject: hardwiring tom tom 300 Reply with quote
hi there
have just bought a tom tom 300 and would like to wire this into the car, is it possible to cut the cable supplied with the 300, and hard wire it into the fuse box,
i have already done this for my road angel but unfortunatly the plugs are slightly different
Ivanm
PostPosted: Sun Mar 19, 2006 12:20 am    Post subject: Reply with quote
If you cut the Cig Lighter Cable and connect it to the Fuse Box, you can kiss your 300 goodbye. Sad
Seriously tho', the 300 runs at 5V and the Voltage reduction is done in the Plug that you put into the Lighter Socket.
If you want to do a permanent job get a cable that has a lighter socket on the end and hide it all away. Or if you're up to it, make yourself a 5V Power Supply that you can hide somewhere.
ivanm
PostPosted: Sun Mar 19, 2006 12:53 am    Post subject: Reply with quote
thanks richard
i have the wire with the lighter socket on the end but how do i hid this away, also do you know how to make a 5v power supply from the 12v system
Ivan
PostPosted: Sun Mar 19, 2006 10:16 am    Post subject: Reply with quote
It can go either in a Glove Compartment or in the bulkhead behind the glove compartment. A lot depends on the layout of the car.
It's a long time since I built a Power Supply. You would need a Fixed Voltage IC, rated at 5V 2A output capable of 30V input. Something like the N2576-5, which TomTom use in their Lighter Plugs. Add a couple of Capacitors, a Diode and an Inductor, fit in a box and 'Bob's your Uncle'.
ivanm
PostPosted: Sun Mar 19, 2006 11:17 am    Post subject: Reply with quote
thanks once again for your help
i think i will try to get hold of cig lighter and then wire that in
Ivan
PostPosted: Sun Mar 19, 2006 12:03 pm    Post subject: Reply with quote
One thing I must add that if you are going behind the bulkhead, be aware that the Airbags are in that area, passenger side anyway, and if you're not sure, ASK.;) Better safe than sorry.
22.064 (26 Jun 24)
